Ft Hood Evo Check-in
#6499
https://www.evolutionm.net/forums/ev...l-think-7.html
#6505
Anyone else on here using the Cobb AP for their X. Today I hit 30lbs and My SAWC light came on and said maint required. Anyway turned it off and Then hit 28lbs. I flashed back to stock and then back to AMS stage 2 and my Boost is back at 25lbs. I've always been on the stage 2 map, is anyone having a similar issue with the AP? With uncontrollable boost?? I have no boost leaks!! Why is it spiking?? I know the X can be super finicky. If I can get a tune with the oem ECU before the 19th I'll be selling my AP for $400
#6507
i havent had any issues with mine yet, everyonce in a while the sawc light will come on but if i turn it off theres no issues.. my boost according to the AP hasnt gone over 28.4psi i dont know if thats right or to high or whatever but never spiked like that..
#6508
Your target boost should be 25lbs but if your boosting 28lbs and it's fine then keep Rollin with it! I seen you yesterday I was in my dirty *** Evo going to wash it today! Do you know the other silver x that lives in heather glen he also has a blue viper truck??
Cobb AP with the X's are hit and miss some work well others don't. But my plan is to go back on the stock ECU
