Ft Hood Evo Check-in
#6516
At the end of the day, everyone knows what an EVO is and in rare form can just about run with anything to a certain point. And with you fellahs getting that good Uncle Sam money, most EVOs there have some work done to it.
#6519
#6524
break break
Anyone around here have a one pair of Clevite 77 CB-1643P STD size rod bearings laying around that they would part with? PM me.
Damn supplier sent me a full set for my eclipse and one of the boxes was missing the partition so the two halves were rubbing and there are some mean gouges. I kind of need/want them soon.
But going back on current topic, stock 10.5cm turbos aliven with all the supporting mods and E85. Tuned right and running 28-30ish PSI they can keep up with my GT35r Evo doing 26PSI on pump until the upper triple digits/top of fourth. Then the difference becomes apparent in fifth. I guess if I didn't granny shift, there would be a bigger gap but thats beside the point. You really don't need much more power unless you want to touch into the 10's or boast high trap speeds.
#6525
well guys i should have some video footage soon , I got a run coming up tonight against an 09 si with a full race turbo kit. His turbo size is unknown but knowing him probably the 30r which sould put it around at least 400whp on low boost.
