Ft Hood Evo Check-in
#7266
Thanks. Sent you a text, but its open for any takers -
I replaced everything from the Head to the testpipe, including every gasket possible. All the factory manifold / O2 housing heat shields were removed, yet I still have the hunting idle and an intense rattling sound when I run the engine up to 4K (it gets asinine after that).
Cash prize and rum to who ever can figure it out.
#7267
#7269
It's very steady up past 4K RPM, and and I haven't found a reason for it to be happening.
Things I'm going to attempt to check today -
1) Drive shaft
2) Drive shaft Heat shield
3) Balance shaft alignment (How can this become unaligned?!)
4) IAC - This is very low on the priority as the idle hunting is only 100 rpm max.
And done
