Ft Hood Evo Check-in
#7673
To all of my fellow gear heads, my brother-in-law bought a 1997 Eclipse GS (against my recommendations) that has all sorts of issues. The car is located in College Station. I told him that I would ask around to see who would be willing to perform the following for him.
1. both inner tie rods
2. both CV axles
3. both lower ball joints
4. both control arms
I told him that I would purchase only Mitsubishi OEM parts. If one of you fellahs want to make some extra $$$, I will drive you down there to perform the work. My brother is in some very bad shape. Turbos are my specialty, not the drivetrain!
2. both CV axles
#7674
2. both CV axles
2. both CV axles
#7675
Hey man, give him a 10lb sledge for a present because that's what he'll need to separate the lower ball joints from the steering knuckles and tie-rod ends . Good luck man/I'm sure there's a good shop or someone that can help around there. You guys are welcome to call if you do it yourselves for pointers but the main one is listed above.
#7680
There is two in temple on Thursday. One is a little more of a mix but pretty small and I don't really go to there's. The one I usually go to is mostly mustangs but non of the guys there are like most of the typical mustang owners. They are trying to get a verifying of cars and they all like imports. I usually go to there Monday mustangs meets. Add ctx tuners on Facebook there all on there. Also there is a ctx awd monsters group on facebook that I'm on.
