any good georgia tuners??
#46
I guess I've been under a rock or something like that for a while, but doesn't the ECUFlash require expert tuning as well? I guess free software is pretty good and all, but I can't see how getting some software (in your computer?) takes you to a state of tune where you can just dial up some boost with a spring, a ball and a screw......
For most people, the simplest would just be to purchase the manual boost controller and crank it up and down as necessary. I was just simply trying to state that it isn't an absolute must to have one.
https://www.evolutionm.net/forums/sh...d.php?t=227006
#47
Sorry, I don't quite understand what you're saying. Of course you can have the ECUFlash "professionally" tuned by anyone that does it, i.e. Dyno4mance or TopSpeed. You can either use a manual boost controller to control boost with the flash OR you can control boost using the stock boost solenoid, a different sized pill, and by changing the WG duty and other related tables in ECUFlash.
#48
As for TopSpeed, don't go there. They'll make your car fast and after it blows up, your screwed. Worst customer service, no follow up, and unexperienced techs. Just look at my signature and PM me if you want the whole story.
Dyno4mance is the Best in the Southeast. I would still have my Evo VIII if i had all my work done at Dyno4mance. Andrew is incredible, and if you want a reliable tune, he's your man.
#49
Hmmm... I guess what I was trying to say is that I don't know about the ECUFlash. Is it some sort of "canned" or off-the-shelf reflash? Or is it a do-it-yourself tune? How do you get the fuel/timing maps right so you can just crank up the boost?..... I mean, I'm not familiar with the ECUFlash. I feel like I've been living under a rock for the last few years...
It allows you to open up and view pretty much anything in the stock ECU from ignition timing maps, fuel maps, rev limiters, wg duty cycle, etc. In essence, it is software that is now available to the general public to modify their ECUs instead of having to send the actual ECU in to places who have would flash them and send them back to you.
Hope this helps, but just check out the ECUFlash section here and this website for more:
http://www.openecu.org/index.php?title=Main_Page
#51
And here's a link to what it takes to make 310awhp (350awho dynojet) on Andrew's dyno. http://www.dyno4mance.com/tuning/project/index.php
#52
#54
#55
#56
Also wanted to add, went down to TopSpeed in Alpharetta today for the first time ever. Doug is an absolute whiz with ECUFlash, and I was more than satisfied with the tune he gave me, car runs great and most importantly to me, smooth.
So now I've used both Dyno4mance and TopSpeed and they have both done great work for me. I think either way, whichever you go to you'll not be disappointed..
#57
