Orlando Weekly Meets
Old Jan 2, 2008, 04:36 PM
  #2116
El.BlueEvo9's Avatar
Originally Posted by Evo2wIsh4
I think this debate wil look good at the track.
That is what I would like to see.
  #2117
Ph3n1x's Avatar
Originally Posted by El.BlueEvo9
Yes, I do spool at idle...........
No Manny the -10.00 psi is what we call vaccum. You are not actually making 10 psi.
Old Jan 2, 2008, 04:39 PM
  #2118
Will geez, I hope well for you and that turbo, I really do, because heck, I might grab me one of those. But until then, it's all talk.
Old Jan 2, 2008, 04:41 PM
  #2119
Ph3n1x's Avatar
I got ur number on speed dial...Look out for the call to set up the race
  #2120
tigeron's Avatar
You gonna break boost like most bigger turbo people do, to us smaller stockish turbo peolpe??????
Old Jan 2, 2008, 04:42 PM
  #2121
Viciouslord's Avatar
i'll bring the video camera....
Old Jan 2, 2008, 04:43 PM
  #2122
But since you think the 20g is a beast on the street, Lets make a Race on the Street (on a closed course, of course). 40-120MPH Shall we? You or your big brother?
I'm game . On a closed course ......I hope you beat us very badly with that big scary turbo of yours.
Old Jan 2, 2008, 04:44 PM
  #2123
Ph3n1x's Avatar
No I have a secret Method I use....Can't tell you!
Ok
Alright Ill tell you~~!- Shhh! I shift to a lower gear.
Old Jan 2, 2008, 04:45 PM
  #2124
Ph3n1x's Avatar
Its not that scary....your scary
Old Jan 2, 2008, 04:46 PM
  #2125
LilRico's Avatar
You guys are just too much!
  #2126
Your the big scary turbo, so we call the shots.
Old Jan 2, 2008, 04:47 PM
  #2127
04AWDTURBOEVO's Avatar
Here it is, Ruben.
This is what it will cost you to get the HTA35R Turbo Kit.
That is a little more than 1600.00 you mentioned. Yes May be the Turbo only. Add the rest of the stuff you need, and bang, you are 4200.00 plus.
Home » Catalog » Evolution » Turbo » Turbo Kits » My Account | Cart Contents | Checkout
CategoriesEvolution-> (350)
BR Staged Upgrades (11)
Engine-> (40)
Drivetrain & Transmission-> (38)
Fuel System (14)
Intake / Exhaust-> (39)
Ignition (6)
Turbo-> (35)
Turbo Kits (12)
Turbo Upgrades (4)
Exhaust manifolds & Accessories (3)
02 Housings & Turbine Housings (4)
Boost Controllers (6)
Turbo Timers & Misc. Accessories (2)
Wastegates,Flanges & Accessories (4)
Suspension (11)
Brakes (6)
Gauges / Mounting (15)
Engine Management (20)
Exterior & Aero Accessories (9)
Interior Accessories (4)
Books and Magazines (2)
Fueling Accessories (2)
Apparel & Stickers (27)
Harnesses & Racing Gear (1)
DEI (70)
1st Gen DSM-> (370)
2nd Gen DSM-> (355)
Other Vehicles-> (52)
2006 Eclipse-> (83)
Quick Find
Search by keywords or product numbers.
Advanced SearchBuschur Racing FPHTA35R Turbo Kit w/ Tubular Header$4,295.00
Click to enlarge
This kit includes everything you need to install this on a Evolution equipped with our front mount kit (other intercoolers do work some may require you to provide a lower intercooler pipe solution).
The kit includes: Ball Bearing HTA35R Turbocharger
BR Produced Tubular Stainless Steel Exhaust Manifold
Buschur Racing 3" S.S. downpipe (not pictured)
TiAL 44mm External Wastegate
Stainless Steel O2 Housing
Replacement Low Profile Cooling Fan
Oil Feed Line
Oil Return Line
Misc. Fittings
Hardware
Gaskets Note: Our kit utilizes the factory water lines.
This kit has been proven capable of making consecutive 9second passes at the drag strip and 600+ whp on the Buschur Racing Mustang Dyno.
You ask... WHAT IS A HTA35R?
The FP3582HTA turbocharger is very similar to the standard GT3582R Garrett turbocharger in overall size and footprint, but that is where the similarities end and your new found power begins. It comes with a 4" inlet and 2.5" outlet anti-surge ported compressor housing. This new and improved style of anti-surge port provides a longer and more gentle bell mouth guide for the air all the way down to the inducer tips. The standard turbine housing is the T31 housing in 2.5" outlet for compact installation applications such as 4G63. Other turbine housings styles are available.
Repeated dyno testing and thousands of miles of street punishment have shown how much faster spooling the HTA is compared to the normal 35R. Midrange and bottom end torque which are usually dismal in regular .82 A/R GT35r kit cars are DRAMATICALLY improved with HTA compressor technology! If you always wanted a 35R on your car, but just could not stand the thought of all that lag - then you have found the answer to your troubles. At 4800rpm the FP3582HTA delivers a 50ft-lb torque increase over the standard Garrett 35R.
This product was added to our catalog on Wednesday 17 October, 2007.Shopping Cart0 itemsNotificationsNotify me of updates to Buschur Racing FPHTA35R Turbo Kit w/ Tubular HeaderTell A Friend
Tell someone you know about this product.InformationShipping & Returns
Privacy Notice
Conditions of Use
Contact Us
Here is a Dyno of the HTA35R on Pump.
Is there Lag?
Here you are Dave,
your Turbo on the same boost you posted.
No lag?
!!ETS 61mm Tuned!!
Well I thought I had better make a thread in the Engine/Turbo/Drivetrain section too, because what I am reviewing here is the ETS 61mm turbo kit. First and foremost, I am not going to repeat myself but I know many of you are aware of my feelings towards ETS, their customer service, and their products. Up until this past Saturday, I did not have any reason to make power/performance claims based on my own personal experiences with anything from ETS, because I had nothing to base them off of other than other peoples' cars and I do not like to do that. Now, however, all I can do is give ETS a huge on all aspects of their work.
The ETS 61mm surpassed my expectations on pump gas alone. I knew that I was dealing with a big turbo, so I was alittle concerned because I knew that I wouldn't be in this turbos efficiency range at only 24psi on pump gas. I wish I had a video of the car on the dyno because at only 17psi, I thought the car was boosting around 30psi; the car sounds sooo mean.
For those of you considering a larger turbo setup, don't just consider the GT35R. The PT61 actually has a slightly larger turbine (by 2mm) and comes with different housings from Precision, a .63a/r turbine housing and a .60a/r compressor housing. All it all, it is a sweet combination that makes tons of power mated up with the ETS tubular manifold and the Tial 38mm recirc dump into the bad*ss 5 bolt downpipe. I haven't experienced absolutely any surging issues at all with this turbo and at this conservative boost level, 24psi, nor have I haven't experienced any boost creep neither.
Combine this kit with an amazing tune from DTM, and you will have some beautiful curves that make some serious power
So here it is on Pure Tuning's mustang dyno (reads just like Buschur's dyno for reference):
Evo IX
Stock cams/head/block/clutch
pump gas
24psi
ETS 61mm
DTM tune
Now here is a snap shot I just took of a log I made about 4 days ago.
22 psi right at 3870 rpms. That is about 600 rpms sooner for the same boost on pump. On race fuel, on 30 plus psi, the Turbo spools even faster at that rpm.
Here is my log.
All facts with pics. No argument here, right?
  #2128
Your scary man from the islands bra.
Old Jan 2, 2008, 04:48 PM
  #2129
Ph3n1x's Avatar
Come on Mannie, Dyno sheets do not give accurate info on spool up.
Old Jan 2, 2008, 04:49 PM
  #2130
Ph3n1x's Avatar
Lol
