Camp Lejeune/Jacksonville Evos
#1742
yo Jason...after a couple days of messing with the laptop, I got it all setup with a dual boot with XP Prof! So far it's working well. It's giving me a little bit of a problem seeing the usb ports...I have to check and see if it's a driver thing. But it logs fine, connects fine with the ecu. It just doesn't like the wideband usb.
#1744
#1745
yup. sp3 installed. Man, finding all those drivers for this laptop (toshiba) was a bish! Thankfully I google searched and found a website that a guy made a rar file with ALL the drivers I needed. Once I got it online too, it found all the drivers it needed with windows update. Pretty cool....
Yeah, I hooked up the cable without it plugged into anything. It needed the cd to load the driver...I think I need to go in and TELL it which usb to use. This damn laptop has 6 on it!
#1746
it shouldnt be that bad... you should have to basically load the drivers for the adapter, then plug the adapter in... let windows do its thing. go to my computer and see what com port it is setting the adapter on (probably 5) and then make sure in evoscan you have the wideband comport set to 5.
#1748
OK. So evoscan works fine. Logs everything totally fine. The problem is when I go to analyze graph data then maptracer. When it opens the load cells only go from 10-100. I have already saved my ROM in the evoscan "ROMS" folder as a hex and xml file. When I right click the lower window of the maptracer to select .hex or .xml I click on my saved ROM and it immediately opens an identical window to that one making me select the ROM again...?? I'm thinking that's where the glitch is. Then, when I select it again to open, I get the error msg...
"Unhandled exception has occured in your application. If you click continue, the application will ignore this error and attempt to continue. If you click quit the application will close immediately.
Invalid character in the given encoding. Line 1, Position 3."
If you click "more info" it goes on and on, with a bunch of script that looks like a xml file.
I have tried it with both vista and xp, and both do the exact same thing. I'm going to un-install both, and try a re-install on xp only...
#1749
Oh yeah, the other weird thing, is evoscan wont save any settings I make to it. Each time I exit the program, it doesn't save any of my hp/tq settings, or my selected items to "datalog by default".
#1750
ok... when it asks for an XML... what it is asking for is the file... so in your case i believe it is the 88590015.xml .... then when it asks for the rom, open your actual rom (the map) the .hex file
see how that works for you if at all. It usually doesnt save setting or at least, the earlier version didnt. I dont use map tracer anymore so i dont know exactly what the newer interface looks like or how it works, but you always had to go in a reload the xml and your rom.
try that and see if it works. let me know...
#1753
Jason, checking on it now. Ive been looking at houses all day....i'll post results..
Track was lame. A typical showing of mustangs and gto's. Got to see what a new G8 could do....14.7....blahh...
#1755
alright...well bad news yet again. It seems the norm with this.
I logged a 3rd gear. When I look at maptracer or any other view, it only logged up to 100 load cell. And at that, all the figures seem to be way off. The afr is showing up as 140-300's, boost didn't log past 2.4 psi.
You think it's the xml file i'm using for the jdm map? could that throw things way off? It's weird too, my evoscan has a bunch of other items i can log. Way at the bottom of the main screen past idc, jdm map, and all that stuff, I have a bunch of other things that were never there. ztx tps, bitflag test, bitflag ztx, stuff like that....wtf...I'm so sick of this.
