Camp Lejeune/Jacksonville Evos
Old Nov 22, 2008, 01:57 PM
  #2641
RREvoX08's Avatar
Location: Tallahassee, but currently reside @ Camp LeJeune
hey guys, awhile back I installed a Forge WGA in the X, Bob aslo previoulsy had installed the Perrin MBC, well with the mbc turned down all the way I was still boosting to 26 psi or higher, so finally after a few over boosts and tired of not having a tune, I took the MBC off today, the car still hits 25-26 psi, but it doesnt spike to it and cause limp mode or any problems, I also installed the AMS intake heat/fan shied whatever you wanna call it, and it has infact done its job and help fixed the damn engine idel issue
RREvoX08 is offline
Old Nov 22, 2008, 01:58 PM
  #2642
RREvoX08's Avatar
Damn bob, I thought you would have had that thing figured out by now...
RREvoX08 is offline
Old Nov 22, 2008, 02:36 PM
  #2643
bigric09's Avatar
i bet when you installed the wastegate, the arm was tightened down to much... so when the boost hits, its not opening as easy as it should so its holding more boost. Unscrew the arm a few turns and try that
bigric09 is offline
Old Nov 22, 2008, 05:39 PM
  #2644
RREvoX08's Avatar
well the forge is almost flush with the bolt the holds it, thats why i need some help to figure out much the forge wga actually pushes out psi wise
RREvoX08 is offline
Old Nov 22, 2008, 05:52 PM
  #2645
Psquared's Avatar
yo. Yeah, I haven't messed with it since the clutch install or dli install...
Psquared is offline
Old Nov 23, 2008, 05:15 AM
  #2646
bigric09's Avatar
the only way to tell is to hook a vacuum pump to it, then pump it until the wastegate opens. That PSI is what its internally set at with no tension. Or, you can send it off to Forge, they will check it out for you. Just tell them you are having issues with it. Have them check out the spring color and see which one is in there. Tell them you want the 15 psi spring i think it is.
bigric09 is offline
Old Nov 23, 2008, 05:42 AM
  #2647
Psquared's Avatar
I'm going to disconnect the DLI and clear the codes. I think it's a coincidence the CEL came on after install. I gotta figure this shiz out. I'm not even driving the car now...wtf
Psquared is offline
Old Nov 23, 2008, 06:19 AM
  #2648
bigric09's Avatar
LOL, good luck man... im sure its something simple
bigric09 is offline
Old Nov 23, 2008, 06:29 AM
  #2649
BensLancer's Avatar
What's goin on? I ain't been on here in a minute! I did learn a life lesson, don't let your wife drive your car, even if it is just a lil slow *** lancer! lmao! she was trying to get out of the way of some moron and ran up on a curb, thus cracking my front bumper, rear bumper, and passenger side taillight! I was glad she was ok, but I paid for all of that work on the car out over straight up overtime hours! So its chillin in my yard until I can cope! lmao! How y'all doin btw?
BensLancer is offline
Old Nov 23, 2008, 06:46 AM
  #2650
Psquared's Avatar
holy f**K!!!!!!!!! I just went and looked around again. And way down in the back by the VSS...(that sensor that naps into the backside of the trans) there's like a 1/2" bolt laying there!!!!!!!! WTF....I'm so F-in pissed. I thought bc they were a new, clean shop the work would be good. I could have paid a local run down shop here 1/2 the $$ and they would have prob at least put all the bolts back in.
I'm calling them tomorrow, asking for a full refund. I have to now go back, re-trace ALL their steps and figure where this bolt came from. Then double check all their work since they obviously can't be trusted....I swear, I am so f---- pissed....I'm shaking. They're lucky they aren't open today....
Psquared is offline
Old Nov 23, 2008, 08:29 AM
  #2651
E VOL IX's Avatar
what size is the bolt a 14 or a 17... i can tell you where it came from..
have a red dot and a 7 on the head or what?? dont freak out...
E VOL IX is offline
Old Nov 23, 2008, 10:48 AM
  #2652
Psquared's Avatar
I would say it's a 14. I don't see a red dot on it. I didn't remove it yet bc I want Nat speed to see their shotty mechanics work. I also crawled under the car and found a 17 that goes into the tcase. It was loose as could be. I could remove it by hand. wtf kind of shop is that?
I'm freaking out bc if they can't get huge a** bolt in the right place, I would have to think others are fuqqed. I also think the drivers side on the trans motor mount now is outta wack. It's not centered in the mount like it was before and it looks like the rubber inside is stretched and pulling out. WTF. I shoulda done it myself.
Psquared is offline
Old Nov 23, 2008, 02:38 PM
  #2653
nymike0731's Avatar
hey bob! where is that link for the mbc
nymike0731 is offline
Old Nov 23, 2008, 02:56 PM
  #2654
bigric09's Avatar
wastegate goes to the center of the MBC, and turbo goes to the bottom
if you are looking to buy one, what you looking for ?
bigric09 is offline
Old Nov 23, 2008, 03:01 PM
  #2655
nymike0731's Avatar
just some info on the install i been checking out some of the how to forums
Quick Reply: Camp Lejeune/Jacksonville Evos
