Camp Lejeune/Jacksonville Evos
#4651
thanks...
I read a couple reviews on that...but haven't looked into them that much to be honest...I'll check them out...thanks man...
Ill look into these also...any suggestions where to find these at a decent price??...I cut a bunch of mid to high 1.6s on my rt615s but I def. won't buy those tires again...
#4653
#4655
#4658
#4660
#4664
The IAC valve is what has the car running rich it is dumping fuel to compensate for air
the rear o2 sensor does not have anything to do with the way the car runs at all.
Please remember this guy has a stage 3 BR motor/full-race head that is going to move a whole lot more air than a stock motor and he is still on a stock ecu, these type of things are going to happen
#4665
I know the rear O2 has nothing to do with how the car runs but he is throwing that code. Might as well fix what you definitely know to be ailing, P0138, and then work from there. Unlike some of the other codes which can have a bunch of **** that causes them the P0138 is simple.
Faulty O2 sensor
Short to battery voltage in O2 sensor signal circuit
High fuel pressure (not as likely)
Faulty O2 sensor
