CFT M Dyno reads low or high?
Does anyone know the history on CFT's mustang dyno?
I got my car dynoed there with a TTP tune and its 255whp and 368 tq (TTP said that TQ reading is wrong).
I have a 2003 STOCK except a TBE (HFC), LICP, K& N Drop in and MBC with a 21 psi pump gas tune.
The 255 number seems low to me by at least 20 hp (unless i have a boost leak wich TTP did not seem to indicate).
Thanks.
Thanks.
The car is not stock with those mods plus the tune, CFT's dyno reads fine I have never heard of anyone have any type of problems or complaints with it. Maybe you want to get your boost logs from the dyno maybe you can figure if you do have a boost leak of some type
Thanks.
Thanks.
If you want to make power than get rid of the catalytic converter, put a real intake on the car such as an INJEN kit with hardpipes, add the O2 housing, Cosworth or Kelford cams and ECU controlled boost from a 3 port solenoid. That should meet all of your power goals.
PcK EvO
74
May 21, 2007 07:12 PM
sway_
Feb 26, 2006 03:32 PM
