So my evo too a crap on me...
on the way to work this morning, i saw a black 04 s2k, the lightly remodeled version.... so i accelerate to get near it to check it out... and he starts hitting it... so i'm following him a bit... my exit comes...
on the exit, i hear all this clutch noise and this is when it starts getting weird...
on the exit, i couldn't get it into gear (any gear), and it was makin all kinds of noises, so i pull it into a parking lot, lock it up and run to my building cuz i was late for a meeting...
so now i'm at work, wonderin what the hellz wrong with my car... i'll probably have to get it towed to the dealer...
just freakin great
just freakin great
Re: So my evo too a crap on me...
just freakin great
just freakin great
Eric
yeah i hate that service manager, rich davis is his name... he is Mr. stiff
man, where can i take this???
should i take it to some tranny shop to have them reattach it?
what do you guys recommend... if i bring it to fountain, they wanna charge me $1300 just to drop the tranny!!! what a bunch of crooks
I have seen this happen to Exedy clutches on the Scoobys.
ok, i'll try that at lunch time!!!
is the throw out bearing gonna be a big deal of a job?
tnx fellas, will let ya know what happens
i had my throwout bearing replaced already .. but it was under warrenty.. the mistu that i go to are very forgiving when it comes to mods. they know your gunna mod the evo so they stick to the warrenty if you have anything that doesnt cause the problem they would fix it.. mabye somthing came loose withing the tarnny. like the shift cables or somthing?
I would consider a tranny shop. Considering that seems to have a real problem with the aftermarket clutches, I don't really think it will matter which dealership you take it to...I just moved to Orlando from Houston...so far the all the local dealerships that I have been in contact with suck. I really miss the one I had in Houston, they seemed to use more common sense as long as the mods were within reason. But even there you probably would be out of luck considering your particular problem. Anyhow, good luck...let us know how it turns out.
ok, went to see my car at lunch time...
with car off:
went into every gear perfectly, no problems, no grinding
put into first and started the car, there was no jerking motion ask Eric mentioned...
so i put it in reverse to move it a bit, when i try to get it to move, it seems as though the park brake is up, or i'm at a speed bump, and when it would move a lil, it would make a really bad metal to metal noise, so i didn't move it at all.
i'm going to get it towed, not sure where though... hopefully it's not my tranny... then i'll have to go JDM 6-speed
derek... which mitsu did you bring it to?
with car off:
