Help me find the cheaper way to lower my car
Old Jul 24, 2009, 03:14 PM
blackheart1425's Avatar
Does anyone know anyshop that would be able to help me lower my car cheap? if you do let me know asap thanks
Old Jul 24, 2009, 03:35 PM
Slyy's Avatar
Most of us go to Malik's shop in Markham.
Install + alignment. Does a great job too
Old Jul 24, 2009, 03:38 PM
LancerGirl08's Avatar
Hit a bunch of potholes till your suspension craps out and you sink to the ground....??
Old Jul 24, 2009, 03:52 PM
hi
Can u give me his numbe and location and how much he charges for lowering
Old Jul 24, 2009, 06:19 PM
jappaswat's Avatar
+1
Old Jul 25, 2009, 01:03 AM
Hydrolikz's Avatar
KSL Auto FTMFW!
Old Jul 25, 2009, 01:56 AM
blancy612's Avatar
Originally Posted by Hydrolikz
KSL Auto FTMFW!
Old Jul 25, 2009, 08:44 AM
WoW
WoW's Avatar
You could cut your springs, alot of the old school civic guys do it.
I wouldn't do it on a newer car tho...
But hey, you wanted cheap!
Old Jul 25, 2009, 08:47 AM
rontam90's Avatar
extra load = lower car
just fuggin' around on a saturday morning. my bad
Old Jul 25, 2009, 09:05 AM
Hydrolikz's Avatar
Even suggesting that is stupid. Cut springs = bouncy failure!
Old Jul 25, 2009, 09:52 AM
absolute's Avatar
cheapest way to have them done RIGHT
springs + matched spring rate performance shocks and struts
though just a mere 200 dollars away is coilovers =P
Old Jul 25, 2009, 12:49 PM
WoW
WoW's Avatar
It's the cheaper way!
And i clearly stated not to do it anyways.
Telling someone to hit pot hole, is stupid.
Giving a name of a shop to do the install + Alignment, is stupid.
Suggesting a shop to someone who wants to get something done cheap is stupid, the cheaper way would actually be a DIY. Springs are crazy easy to swap anyways.
Are you not going to comment on their posts?
My reply was actually the only real helpful post in this whole thread, other then absolute's second post.
man oh man, is this club full of knowledge
Sorry for going OT, OP.
Doesn't Megan or BC racing make a cheap set of coil overs for lancers?
It'll be ~900, It's a easy DIY (Heck, i can even help you out) and you won't have to worry about blown struts or camber limitations later on.
Old Jul 25, 2009, 01:11 PM
My post was an obvious joke.
Old Jul 25, 2009, 02:48 PM
xCASHx's Avatar
cheapest way is to just get springs and install yourself.
U can get Eibach sportlines shipped to ur door for $300. Only problem is that I give it maybe a year before ur struts blow and u need a camber kit eventually so u dont go thru rubber like crazy.
so really after u get springs, struts and a new camber kit, which u dont have to do all at one time just when ur stock ones give out it will be closer to what a set of coil overs would be.
and coil overs are pretty much the best way to do hieght mods to your car. Only thing is that if u get springs the ride will remain comfortable and with coil overs I've noticed a very stiff feel.
*that last part is is just my 2 cents*
Old Jul 25, 2009, 03:24 PM
WoW
WoW's Avatar
Coil overs often at least have have Rebound / Compression dampening adjustment, simply soften the compression and the ride should be OEM like.
I say 'often' but really mean most, only the REALLY low end coil overs don't offer such adjustments.
I'd go for coils, and a DIY install, OP!
Quick Reply: Help me find the cheaper way to lower my car
