HSD Coilover install + 2 season adjustments/alignments= Dealership $1700 Offer
1 Post
Hey guys, Good news, our gold alliance dealerships are stepping up and offering a great deal for HSD coilovers for the EVO X and very soon the Rallart / Lancer. Each dealership will have a limited stock of HSD coilovers to install so act now.
Erin Mills = 2 kits - Speak to Josephine
Maple = 1 kit
Scarborough = TBA
Dixie = TBA
What is included for 1700 + tax
HSD Coilover kit
Coilover Install + Alignment (now)
1 Season adjustment (later)
JUMP ON THIS NOW!!!
HSD Coilovers use a very well respected and proven Monotube damper design combined with high quality hardware. This level of quality and performance is usually found on much more expensive suspension products. This is high end competition winning suspension available direct from the factory at affordable prices.
High Quality Monotube Dampers
Due to the excellent handling characteristics of our Monotube dampers, HSD coilovers give a supple, sporty and perfectly damped ride.
They soak up bumps and jolts effortlessly, yet firm up when needed to give exceptional roadholding and handling on fast road and track.
Cheaper aftermarket dampers use a twin-tube design with low pressure gas whereas our Monotube damper design uses large diameter pistons and a much higher gas pressure to better stabilise the oil within, even under extreme and prolonged use.
Height Adjustment
Ride height is fully adjustable on all our coilovers by adjusting where the mounting bracket sits on the damper.
This means a very wide range of height adjustment is possible without affecting the spring pre-load or the damper stroke length. So whether you want sporty or totally slammed, you still get the full performance of the damper.
Fully Adjustable Damping
Our 16 Stage damping adjustment allows quick, easy and accurate control of the damping so you can tune it to suit your style and setup.
Set to soft for your daily drive, then quickly switch to hard for track days or competition use.
Pillowball Top Mounts
Our coilovers come with Anodised Aluminium top mounts with integrated heavy duty noise-free pillowball bearings all round. This means you receive a complete package where the damper is precisely connected and working in tune with your car.
A wide range of camber adjustment is included on front strut models.
Maple = 1 kit
Scarborough = TBA
Dixie = TBA
HSD Coilover kit
JUMP ON THIS NOW!!!
Height Adjustment
1 Post
I have gotten messages about this already, contact the dealership directly. To answer 2 of the questions in one shot.
Yes this is a one time deal. The price for this will likely go up. So if you have been inchin to get coilovers I would speak up.
you need extenders for the back to adjust the stiffness. I have BC BC EB series coils and the back are covers by the body so you have to drill a hole and feed the extenders through. there is one hole conveniently on the left but not the right.. just a lil info for ya
LSD Motorsports
Vendor Classifieds
10
May 18, 2017 03:19 PM
IMPORTIMAGE
Lancer Vendor Classifieds
378
Jul 13, 2016 06:51 AM
Speed Element
EvoX 'For Sale' Suspension / Brakes / Handling
60
Dec 7, 2012 09:21 PM
TalonRcR
Evo 'For Sale' Suspension / Brakes / Handling
34
Apr 10, 2007 01:11 PM
DrivenConcepts
47
Aug 7, 2006 08:30 PM
