Canadian Tire Digital Impact Wrench - This Thing Any Good?
Used it on several occasions, from changing tires, to changing suspension, control arms, etc...
+1 for the item from me
Whether or not you want the one that's digital and a little more fancy with controls is all up to whether you'll actually use it to torque things down to the #'s. If the answer is yes then go for it, real great buy, specially if you like working on your car.
Dj
Hmm... I just used this impact wrench to swap my tires... and the best I can say is that it's "okay". It couldn't even take off the original lugnuts that were on the car. I had to take them off by hand. Then once they were loose I used the impact gun to take off the nuts quickly. I was a bit disappointed in that because they claim the impact wrench is not supposed to limit torque when removing the lugnuts... but it obviously was. And I didn't have to turn that hard to loosen them by hand.
This tool was helpful in that I didn't have to spend forever to hand loosen and tighten each of the lugnuts... but otherwise the torque settings didn't seem all that special. It's like using a glorified drill.
And for what it's worth... I tightened the wheel with the impact wrench at the 80 lb-ft setting... but when I used a torque wrench after... I had to turn it even more for it to go off at the 80 lb-ft setting on the manual torque wrench.
This tool is good at speeding up the process of loosening and tightening the lugnuts... but it's far from a precision tool.
FS[Northeast]: Evo 8 Enkei's with Mastercraft GlacierGrips
ProPilot04
For Sale - Wheels / Tires
Sep 12, 2014 09:19 AM
GTSZEUS2010
Jan 28, 2011 04:15 AM
