Question for those who have 235/40 18" tires on Lancer
Was wondering those who were successful in fitting 235/40 18" tires without having to roll fenders, what kind of offset were the rims you were using? I am interested in doing this if I don't have to modify the fenders.
I am currently running MOMO Next 18" with offset of 45 and 8.0 that will fit 235 width tires fine. But don't know if I will have issues if I make the leap, so asking those who have made the leap on their results. Currently I find 225/45 works no problems, I would like to try 235/40 next tire change if it works.
Please comment!
Please comment!
I just started running 18x8.5 +38 offset 235/40/18 lowered on Tein S.Tech's (Exact same thing as CARVS), but I rolled the fenders at the same time! It was a $120, why not!
235/40/18 18x8 with 40ET - border line and NO fender rolling with stock susp. Have no rubbing with car fully loaded.
If comparing to Carvs set-up, his tire sticks 2mm further out than mine and is 2 mm further away from suspension than mine. As it was said before - it's a fine line.
Use this calculator: http://www.rimsntires.com/specs.jsp I found it to be very usefull and fairly true to actual measurements.
evil03
1180
Sep 21, 2021 10:31 PM
Turbotech
21
May 21, 2011 08:42 AM
DOHCtor
10
Dec 2, 2010 03:43 PM
