Upgraded Tranny Parts
#32
Tranny
Listen, Im not sure what the deal is with the different dealers. All I know is that I just got my car done and I had no trouble or issues at all. With my after market parts on and all the car was serviced with no questions asked.
All I can say is thank goodness for recalls!!!!!!!
When I get home I will check my receipt and see if they put a code or something that would say anything about the recall.
Ill be back later.
Ill be back later.
#33
Tranny
Ok, here is what the dealer put on the receipt-
Internal defect in Transmission
Transmission assembly overhaul #22201020.
They overhauled the following-
1 MR581385 Ring Assy, M/T 2nd speed
1 MD748058 Ring M/T Synch
1 MR581388 Sleeve, M/T 3rd & 4th Synch
1 MD770348 Ring Assy, M/T 3rd Speed
2 MR581389 Spring, M/T Synch Key
1 MN168859 Sleeve M/T 5th & Rev Synch
1 MR581382 Ring M/T Synch
2 MR581383 Spring M/T Synch Key
1 MN168934 Ring Assy, M/T Rev Gear
1 MD997740 Liquid Gasket, M/T
2 A991zc2x01 Lube gear, Diamond 5G
C0409zxx Fan controller
This is exactly what was was done on my car for the tranny recall. Not sure what the fan thing is but I guess I got that also.
So there you go, its all in black and white. I hope this helps!!!!!!!!!
#34
#36
something like that. Looks like they tossed that on as long as the car was there.
#39
My synchros are being redone under warranty right now. The tech asked if I wanted to change my clutch for free of charge, I said no I rather trust my friend who can do it for a couple of beers
They will probably cover the synchros under warranty if changed out your clutch. Engine mods are probably fine though.
#40
I'm having the synchros changed under warrenty on my 04. Thinking about having them put in a ACT Street Clutch - except it's a bit expensive. Is the ACT a good $500 investment?
Nice to hear new synchros make a big difference.
#41
#45
I brought my car in two weeks ago. They are going to give me a transmission rebuild. My car would not go into reverse. The only thing that I am pissed off about , is the fact they are taking their sweet time fixing the car.
