EvolutionM.net's ZEITRONIX Master Distributor!
I was wondering what the cheapest set up you guys carry for a wide band from Zeitronix.
Ive been running a Innovate WB for two years but Im on my third one now after having to send them in. I also just bought a labonte meth kit so it would be nice to set it up as a fail safe down the road.
I just want a wide band for now to get my AFR back in check and Ill buy the rest later.
I tried to pm you but your in box is full
TTP-Engineering would like to announce that we are the Master Distributor for Zeitronix products here on evolutionm.net.
As the innovator of a number of features the zeitronix is now capable of, we continue to work on the development team to help find new ways the system can benefit the end user.
Our trademarked meth injection safeguard system leaves much to be desired from every other wideband in the marketplace.
If anyone has any questions about the system, its features or components, options prior to purchasing, please feel free to contact us.
WE HAVE ALWAYS AND WILL CONTINUE TO SUPPORT ALL OF OUR ZEITRONIX CUSTOMERS WHO NEED INTELLECTUAL ADVICE IN APPLICATION AND USE OF THEIR UNIT.
FROM WIRING SCHEMATICS, TO PROPRIETARY WIRING APPLICATIONS WE HAVE DEVELOPED, WE ARE MORE THAN WILLING TO SUPPORT OUR CUSTOMERS WHO HAVE PURCHASED ZEITRONIX PRODUCTS THROUGH US.
QUESTIONS CAN BE DIRECTED TO (407) 475-0010 or EMAILED TO SALES @TTP-ENGINEERING.COM
Below are some example packages that are offered and are IN STOCK.
No dropshipping of products (fake inventory lists)
Package #ZR1R- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-1 GAUGE IN RED LED that displays AFR. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Includes the ZR-1 Gauge plus Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and ZR-1 Gauge with peak and hold feature. High contrast LEDs visible even in a direct sunlight. Made in the USA.
__________________________________________________ ___________
Package #ZR1B- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-1 GAUGE IN BLUE LED that displays AFR. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Package #ZR2BL- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-2 GAUGE IN BLUE LED Multi Gauge Combo which can display AFR, BOOST, EGT or LAMBDA and is switchable! Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box. Includes the ZR-2 Multi Gauge and Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and ZR-1 Gauge with peak and hold feature. High contrast LEDs visible even in a direct sunlight. Made in the USA.
Zeitronix ZT2 wideband only for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Includes the Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, Datalogging Software, Installation Instructions and 2 pin EGT connector to retrofit your EGT probe.
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging! Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging. Also includes low mass, high response K thermocouple EGT sensor for lightning quick EGT logging and viewing on the LCD display. Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, EGT, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging. Also includes low mass, high response K thermocouple EGT sensor for lightning quick EGT logging and viewing on the LCD display. Also includes ZAVT- Zeitronix AUDIO-VISUAL alarm and safeguard trigger. FULLY PROGRAMMABLE warning LED and alarm that you can bas on simple EGT, AFR, BOOST, TPS, RPM and/or COMPLEX warning such as (IF AFR> 12.00 AND BOOST >22PSI AND TPS> 75%, THEN TRIGGER WARNING). This feature works especially well with TTP-Engineering's meth injection systems to insure a trouble free tune. Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, EGT, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
[/B]
[/B]
CO_VR4
Dec 22, 2016 05:57 PM
Dimmoun
Apr 19, 2016 12:20 AM
TTP Engineering
Evo 'For Sale' Interior Styling
141
Jun 3, 2010 10:21 AM
TTP Engineering
62
Apr 24, 2009 03:26 PM
500whp.com
40
May 18, 2006 10:29 AM
