**Product Release**AMS Mitsubishi Lancer Ralliart Cat-Back Exhaust System
The AMS Mitsubishi Lancer Ralliart Cat-Back Exhaust System is the most unique exhaust system on the market. It was designed to be used with the same high flow cat, resonated test pipe, or test-pipe used on the Mitsubishi Evolution X. It can also be directly bolted on to the factory catalytic converter.
The AMS Ralliart Cat-Back Exhaust System has undergone countless hours of research and development and has been designed to make the most horse power as well as shed serious weight off your Ralliart. Our exhaust features mandrel bent piping for the best exhaust flow. This system does not have any restrictions like other popular exhaust systems that "neck down" and hurt performance. Like all other AMS exhaust products this Cat-Back is TIG welded with 100% 304 stainless components including the flanges and hangers. The system utilizes factory exhaust hangers and includes a high quality slash cut 4" tip muffler. By simply installing this exhaust system you can expect to see as much as 15+ Wheel Horsepower gains over stock without even re-tuning the ECU!
Features
• 3" throughout entire system. Does not "neck down" like other systems
• 100% Stainless Steel construction. No mild steel flanges or hangers
• All flanged connections. No band clamps or slip fits to come loose
• 15+ Wheel Horsepower gains over stock
• 24 lb. weight savings (21 lbs. compared to stock at 45 lbs.)
• 6" Of Ground clearance, no lower than the factory cross member
• Bolts up to the factory catalytic converter, AMS High-Flow Cat, AMS Resonated Test-Pipe or AMS Test-Pipe
• Includes gaskets and hardware (2 bolts and 2 gaskets, re-use 2 stock front bolts)
• Unrivaled fit and finish
Specifications
• 304 Stainless Steel
• 3” piping .049” wall thickness
• Polished Muffler w/ 4” Cut Tip
• 3/8" Thick Stainless Steel flanges
• 21 lbs
Applications
• 2009+ Mitsubishi Lancer Ralliart
EMISSIONS STATEMENT: Federal and many state laws prohibit the removal, modification or rendering inoperative any part that affects emissions on motor vehicles used on public streets or highways. Many Automotosports parts are designated for track use or off-road use only. Installation of certain components may bring the vehicle out of compliance with safety and/or emissions standards. Automotosports recommends that vehicles with parts designated in this fashion not be operated on public roads. Automotosports customers are responsible for complying with applicable state and local environmental regulations.
**Click Here To Order**
that nice exhaust. so does it fit with aftermarket evo x testpipe. for example i bought your exhaust and i bought another company test pipe for evox, ams exhaust would bolt on no problem.
never mind i just read the otherpart ams products for the evo x bolt on parts for the exhaust, i got it. i need more hp raced couple cars lately, with base flash, pill, intake. i get them low end around 85 to 95mph pretty even,then few more mph they start to pass. so next is ams exhaust + evo x ams test pipe, then ams front mount.
Can we get a sound clip please? Can we get a picture with it installed? Also which down pipe can we use? I noticed that your Evo X down pipe does not specify 2009 Ralliart. Can it be used? I also noticed your down pipe is on back order. Any plans of making more so I don't have to wait 2 months for an exhaust?
Unfortunately we can't produce a sound clip due to our Ralliart having an Evo X turbo on it and also our wide mouth down pipe as it would sound the same on another stock Ralliart. We would be willing to offer a discount for a member here to purchase the exhaust and post up a sound clip for customers to hear. Also our wide mouth down pipe does not fit on the Ralliart unfortunately. At this time we don't have any plans to offer a down pipe for the Ralliart or a twin tip exhaust. I will keep you guys posted if anything changes.
PMed
