SparkTech's *NEW* QUICK DISCONNECT option
Introducing Spark Tech's Quick Disconnect Option for the CDI systems.
This option enables users to quickly separate the mounting plate and coils from the balance of the wiring system. This makes changing plugs & other routine maintenance easier as the entire system does not have to be removed or disconnected.
This is a high quality, sealed connector. Designed for high heat, industrial, automotive and marine use. It is specifically designed for power and signal connections. There is little to no signal or power loss.
