NEW RELEASE!! Precision Turbo Billet 5857 Turbo w/ PTE Cartridge!!!!
Old Oct 27, 2009, 06:50 PM
  #121
AWD Motorsports's Avatar
Originally Posted by cincy
I was torn between the 6057 and 5857 but went with the 5857 for my TT. Should make for a great street turbo.
Anyone else notice a high difference in ratings from sites?
5857 - 500hp (treadstone), 605hp (extremepsi), and 615hp (ETS turbo)
6057 - 550hp (treadstone), 630hp (extremepsi), and 630hp (ETS Turbo)
Wonder who has the real rating....
ETS has the right rating based off PTE Spec Sheets.. I have made More HP than the rating on every billet turbo i have used so far..
Mike
Old Oct 27, 2009, 06:53 PM
  #122
Force-Fed Performance's Avatar
Mike we decided with the 5857 for that build i discussed with you
our spec 2.0
Buschur race head
BR272
E-85
Double pumper
blow thru
ETS 5857
Should be sick nasty
Old Oct 27, 2009, 06:55 PM
  #123
cincy's Avatar
Mike
Perfect, thanks Mike. Results should be more than promising with my 10:1 2L TT
Old Oct 27, 2009, 11:26 PM
  #124
ETS Michael's Avatar
Mike
I believe that! They rate the 6262 almost 130hp lower then what we have seen put to the ground.
Thanks,
Michael
Old Oct 27, 2009, 11:27 PM
  #125
our spec 2.0
Buschur race head
BR272
E-85
Double pumper
blow thru
ETS 5857
This setup is going to be sick!
Michael
Old Oct 28, 2009, 01:46 AM
  #126
JC evo1's Avatar
do you think either of these turbo's will make power to 9krpm or a fully built 2L? I like my 35r, but i would swap it if i could find something with a far better midrange and similar top end. HTA82 doesnt really look worthwhile for me.
Old Oct 29, 2009, 04:49 PM
  #127
phat's Avatar
Would it be no good to put a 5857 on a 2.5L? Mike you said you put one on rb25 is that right, could you please post up the dyno sheet as i too would like this turbo on my 2.5L
My RB25 revs to 9000tpm also so i would like to know your thoughts on turbine housings.
Thanks
Old Nov 2, 2009, 11:27 AM
  #128
luvnish's Avatar
Awesome turbo can't wait for the results.
Would you recommend .63 or .82 A/R for this turbo?
Old Nov 3, 2009, 07:45 PM
  #129
EvolutionRey's Avatar
Any up dates yet?
Old Nov 5, 2009, 07:08 PM
  #130
ReDsRtKiD's Avatar
subscribed for updates.
over on srtforums there's a rumor goin' around that they are stopin' the production of allll 60 series wheels...any truth to that Mike? I hope not.
Old Nov 5, 2009, 07:12 PM
  #131
Most turbos in t3 wont hold power to 9k.. The only 1 i know is the 6765 billet.. The smaller turbos drop off.. id have to look at my 6262 that made 780whp to see what it was making at 9k.. i dont remeber exactly..
Mike
Old Nov 5, 2009, 07:13 PM
  #132
Thanks
The rb25 sucks the 5857 dry.. Thats a 6cyl that revs.. it needs more turbo than 58mm to hold power to 9k.. the small rear wheel doesnt help either.. i would go 6262 on rb25..
Mike
Old Nov 5, 2009, 07:14 PM
  #133
Ill have to ask i dont know the answer to that.. The 60 series is a different blade config than the 58 so i dont see why they would cancel other than that the 58mm might make more peak power on higher boost levels..
Mike
Old Nov 6, 2009, 04:22 PM
  #134
luvnish's Avatar
I spoke to Michael Bacon from Precision to learn more about the 5857 and 6057, this is what he had to say:
I believe that the 58 billet is a better designed wheel and may be able to support as much on top, at the same time being more streetable.
Old Nov 6, 2009, 04:40 PM
  #135
06ravenmr's Avatar
i want a 5857 sooo bad. sucks i have to spend the money on a f'n clutch...
Quick Reply: NEW RELEASE!! Precision Turbo Billet 5857 Turbo w/ PTE Cartridge!!!!
