9sec9.com C/F components in stock and available now!
Our Cam Sensor Heatshield protects the cam sensor from heat created by exhaust manifolds. Heat can destroy the cam sensor causing catastropohic engine failure. These are made from carbon fiber and are covered with a heat reflective film that reflects 98% of radiant heat. More info can be found in this review https://www.evolutionm.net/forums/se...or-shield.html
This Carbon Fiber Heated Air Block STOPS! the engines hot air from being pulled into your air filter. We've seen many Boxes, air tubes, etc to get fresh air to your air filter. We wanted something simple to install, inexpensive and functional. After testing this on Indy's car, the times dropped from 11.82 to 11.66 and the MPH improved. Before, we saw intake air temps not 'clearing out to ambient' until the car was well down the track and at the top of 3rd gear. Now, every pass shows the intake temps going ambient by the top of 1st, but no later than early 2nd gear. Every improvement helps when you're squeezing hundredths out of your times. These are only available for stock intake tube applications, stock battery, w/Vibrant MAF adaptors. We are working on an additional part for the FP intake tube and also mini battery applications.
Heat Block for Mini Battery applications.
We also will be offering a DIY "trim to fit kit: upper panel, these will not have the scoop of MAF holes.
This lower panel is also a DIY " trim to fit kit" since there are so many variations of LICP and intake tubes, and will be available for those who wish to seal off the Heat Block to the frame rail.
Carbon Fiber aerodynamic panels for lower, front bumper area. Fits Mitsubish Evo IX. These clean up the front bumper cover and reduce "aero" drag and are used by some of the quickest and fastest Evo IX's on this forum.These panels are generally installed using clear heli tape or double sided tape at critical points on the back side. These panels are built exclusively for 9sec9.com by the same company that builds many Indy car body parts.
Upper Bumper Duct Shutter, Intercooler Shutter for water to air intercooler applications (to be used with Aero Panels Shutters), Side Mirror Delete Panels
These components along with Wilson Manifolds record setting W series intake manifolds, D-Rail fuel rail kits, Nitrous Pro Flow systems, Hoosier 245/45/17 Drag Radials and more are available now at 9sec9.com. 9sec9/Indy - Spark Tech ignition's coming soon.
You can check out 9sec9.com for pricing and availability.
We should have a shield for the mini battery ready to proof in another week, along with a new MAF bracket.
Welcome Carz Performance in Lakewood, Colorado 720-214-5095 our latest distributor of 9sec9.com racing components .
Think about how much time at idle goes by between the staging lanes and the staging lights. Before the heat block, the intake temps would not reach ambient tempurature again until well down the track, usually 3rd gear. With the block, the intake temps go ambient often by the top of 1st and no later than early 2nd gear. Heat kills horsepower. Nice job Jim.
I have a buschur intake and nisei mini battery kit but I want that carbon heat shield very badly! Please hurry and produce one so that I can buy it! I also like the weave/coloring of your carbon fiber, so If you are going to be making any other pieces such as spark plug covers or timing belt coves, please let me know.
-Ben
-Ben
-Ben
-Ben
Since there are so many different combinations of tubes and filter assemblys, we will make some panels without the hole for the stock tube and MAF. These would be a trim to fit kit for DIY guys, and should cover a wide range of tube filter combos.
We are two weeks away from a mini battery version.
Edit: I am working on trying to find some type of 3 inch air duct, like companies use for their brake kits, so I can run the air duct from my front right air dam up to my perrin filter and THIS piece would be VERY nice to finish off my setup with...
Great talking to you 06, I'm looking forward to the photo's. I know we can whip something up that will work for you. Indy
Only 3 Cam Sensor Shields, 1 Heated Air Block, and 2 sets of Aero Shutters left untill the first week of December order yours today!
