MAP O2 Eliminator Downpipe Helps Power 9sec9/OKIX to 9.53 @ 148mph!
I know this is old news by now, but I wanted to congratulate Tom on his latest accomplishment and wish him the best in his quest for low 9's on a stock frame turbo! We are excited to be even a small part of your continued success!
Originally Posted by 9sec9
Your (MAP) O2/Tial dump was the perfect combination for putting our Wilson Manifolds Evo IX into the 9's. It worked perfectly in every respect. It' only a matter of time until others begin to use this combination of winning parts.
I just logged in and saw this thread. Chris, I have to disagree about this being a SMALL part of our success. When Indy and I decided on what we needed to control our power, I began looking for the "parts" to get the job done. Through a google search, I was directed to your thread about this and couldn't believe that MAP had already built EXACTLY what we wanted to build. Not close, but exactly. This piece, in conjunction with our boost control system, has made it extremely easy for us to test at different boost pressures. It allows us to keep the turbo shaft speed at optimum rpm's, without over spinning, or leaving too much power on the table. There's very few parts that I'll endorse for ANYONE, but this one is right at the top of my favorite list. Thanks again for building it.
added: As for the flapper. I learned last year that the flapper only needs to open very slightly to control the boost. Knowing that, I didn't want to modify a perfectly good housing, so I simply opened the flapper up to full-open and used a strong spring to keep it there. No mods, just a good spring. Boost is perfectly controlled without having to modify the turbo.
I've wanted to use a AMS 500 for a while now. I will be switching over to the MAP MVS DP and the 500 next year after I get the initial bugs out of my setup. Keep up the good work MAP and 9sec9.
maperformance
11
Aug 24, 2011 11:58 PM
maperformance
207
Jun 15, 2011 04:03 PM
maperformance
Vendor Classifieds
54
Jun 1, 2009 08:13 PM
maperformance
Jul 24, 2008 07:23 AM
