Buschur Racing 1/2 width radiator
If the radiator is installed like it is intended, with removal of the a/c, it would cool as good or better than stock. There are a LOT of these out there already, we've just improved on the looks of the product by having it made custom from start to finish. My car typically will not run over 185 degrees.
NO problem at all doing the thermostat housing or the water feed pipe. We can weld those up very easily. I don't know how much the thermostat housing neck and water pipe cost, I'm assuming it's better for you guys to send your parts to us to have modified/welded. We can do them very reasonable.
Conrad, what is "craic"?
Good product
