MAPerformance Releases Turbo Outlet for Evo 8 & 9
#47
Well they sell all three and I'm picking one up from MAP regardless which one they choose, so I'm hoping they will give me their honest opinion.
The Invidia and Titek are larger than MAPs version so what makes MAPs flow better? The port work?
Also what's everyone's opinion on coating? Should I get it coated or not? Thanks.
#50
The problem why nobody makes a 3" outlet o2 housing is because downpipes on the market as designed for the stock o2 housing which is 2.5" outlet. Nobody wants to make a 3" downpipe and not have a o2 housing that is required to install it.
That is why we made the o2 eliminator downpipe, because instead of making a o2 housing and a downpipe, because you can't buy one without the other. You might as well get the full 3" assembly without any 2-bolt connections.
We would add a v-band to our o2 eliminator downpipe but there is no room where the traditional connection would be.
Its a huge debacle and headache, and in my opinion the best option is our downpipe, its 3" continuous and if you would like to be two pieces, you would have to do it after the oil pan.
