*NEW RELEASE!* Koyorad cooling solution for front facing turbo systems!
![](http://i981.photobucket.com/albums/ae294/vividphil/Vivid%20Racing%20Products/koyo.jpg)
Koyorad is proud to introduce a cooling solution for 2003-2007 Mitsubishi Evolution race vehicles with upgraded front facing turbo systems. For off-road use only, this half length radiator is intended for sprints, small track, and gymkhana type courses. It features an all new, ultra high density 48mm “Hyper” performance core. The reduced length allows for an off-center mounting position, which keeps radiant manifold heat away from its core. Like every Koyorad All Aluminum Performance Radiator, the OEM electric fan will bolt up directly without modifications. Unique sliding fan mounts allow for an easier installation of aftermarket universal slim fans, freeing up additional engine bay room and reducing weight. Koyorad integrates a 1/8” NPT female accessory fitting (supplied with a threaded plug) to accept temperature sensors typically supplied with most aftermarket temperature gauges. This radiator will fit global market Evolutions: IV, V, VI, VII, VIII, and IX.
Koyorad’s global reputation for high quality cooling products begins with the selection of the finest materials. Koyo privately owns each factory, never outsources their manufacturing and overseeing each stage of production using Japanese made equipment throughout the production of each radiator. Koyorad All Aluminum Performance Radiators are hand assembled, precision TIG welded, and triple pressure tested throughout the manufacturing process contributing to reliability and uniformity. The superior quality of Koyorad all aluminum radiators will take your vehicle’s engine performance to the next level.
Features:
• Koyo “Hyper” Series 48mm Core Technology
• Reduced size and weight
• Exclusive brushed aluminum finish
• Nocolok-R Brazing
• Precise Tube and Fin alignment
• Billet aluminum filler neck
• 1/8” NPT Accessory Fitting and threaded plug
• Billet aluminum drain plug
Application: 03-07 Mitsubishi Lancer Evolution
Koyo Part Number #: HH032412
Available: December 2010
Thanks for looking,
Phil
RallySport Direct
Vendor Classifieds
158
Jan 16, 2015 04:05 PM
JBAutosports
101
Nov 18, 2012 05:03 PM
JBAutosports
EvoX 'For Sale' External Engine / Power
60
May 8, 2012 10:56 AM
Vivid Racing
25
Apr 23, 2012 09:46 AM
TitanMotorsport
22
Feb 22, 2011 12:19 PM
