New DW300 Fuel Pump - 300LPH In-Tank!
DEATSCHWERKS 300LPH In-Tank Fuel Pump
January 2011 Release!
DW300 Highlights:
- Meets SAE guidelines for fuel pump testing
- Application specific install kits included (Universal also available)
- 3-year, no-fault warranty
- The DW300 is a turbine impeller pump
DW300 Specs:
- 300LPH+ @ 3bar fuel pressure.
- 100% E85 Compatible
- 39mm body for in-tank applications.
Thank you for checking out our DW300 release post. Feel free to ask any questions about the pump in this thread. Also, we will be posting any updates about the pump in this thread.
If you are running the same fuel pressure, you shouldn't need a reflash. Though, any time you are changing the fuel system, it is a good idea to have the ability to monitor the fuel stats to make sure you are still running within the scope of the tune and safe operating limits.
The DW300 has similar dimensions and fitment to the GSS342, so if the DP setup you are using is designed for that pump or one of similar fitment then the DW300 should fit, too.
1 Post
No, it won't fit. At least it won't fit a BR Double Pumper. This was discussed today:
https://www.evolutionm.net/forums/ev...pumpers-2.html
Still- this is a very nice option to have
-Bink
