Toxicfab's new O2 dump!!! Look!!!
#31
Well i know who wil be making all my metal work once we get our second project evo,,
Alright everyone!!! I finally took the time to use my car and build a new product. It's hard to build new products without having a car to jig new parts on. So I took my daily driver and used it to make a new 02 dump for the Evo community. In the process I snapped 3 bolts off in my new FP black and have no car now but it's worth it! Because there's a new product for Toxicfab.
This 02 dump is constructed of all 304L stainless steel parts. I tried to switch it up from the rest of the dumps out there. Many companys make the bend in 2.5" with a slash cut to fit it to the down pipe flange; I used 2 bends to correct this. I've also noticed a lot of the dumps available are not back purged. My 02 dump is 100% back purged. I also made sure my dump tube is long enough to not cover your oil pan, ac compressor, and ect. in soot. I also added a slash cut to make sure its dumping on the ground and not the mentioned areas above. It clears the ac line perfectly. Keep in mind the one im posting pics of is a protoype built off my car, so the final product will change slighty. For example, I am using a tighter radius bend for the 2.5'' section to eliminate the oval opening from the tight angle needed to make this fit correctly, but enough with the talk here are the specs and the pics!
Toxicfab O2 dump for Evo 8&9 direct bolt on part.
-All stainless flanges-
-recessed pocket for wastgate-
-100% precision tig welded-
-100% back purged-
-fits all lower ic pipes-
-fits to factory or after market down pipe-
-uses factory donut gasket-
-added ring to seat gasket properly-
-flange threaded for factory bolts-
-price is undecided-
-should be avaible in a week or 2-
PLEASE PM ME FOR DETAILS!
Uploaded with ImageShack.us
-100% back purged-
#39
Dan (drb)
