NEW RELEASE!!! Torque Solution Evo 5-9 Engine Mount Inserts!!!
We are proud to announce the release of a new Torque Solution EVO 5-9 Engine and Transmission motor mount inserts.. Any questions PM us.. Information is below direct from the torque solution website..
Torque Solution Driver / Passenger Engine Mount Inserts : Mitsubishi Evolution 5/6/7/8/9
Torque Solution polyurethane engine mount inserts that replace the inner rubber material of the OEM EVO 8/9 engine mounts. Made from 75a durometer polyurethane. Each mount includes 2 half's and a center steel sleeve. These give you improved traction and reduced wheel hop without to much vibration. Bushings come with a lifetime warranty through Torque Solution. Fits Drivers side housing and Transmission Side..
•Eliminates wheel hop / traction loss
•Improved 60fts / e.t's
•600HP+ and 9sec e.t. torture tested
•75A durometer bushings
•Life Time Warranty
•Made in USA
Torque Solution Front Engine Mount Inserts : Mitsubishi Evolution 8/9 2003-2006
Torque Solution polyurethane engine mount inserts that replace the inner rubber material of the OEM EVO 8/9 engine mounts. Made from 75a durometer polyurethane. Each mount includes 2 half's and a center steel sleeve. These give you improved traction and reduced wheel hop without to much vibration. Bushings come with a lifetime warranty through Torque Solution. Fits OEM Front Mount Housing..
-Eliminates wheel hop / traction loss
-Improved 60fts / e.t's
-600HP+ and 9sec e.t. torture tested
-75A durometer bushings
-Life Time Warranty
-Made in USA
•Life Time Warranty
•Made in USA
-Life Time Warranty
-Made in USA
