Available SST Replacement parts and prices
We stock the following parts for the Getrag DCT 470 (SST) Transmission. We also have some items not listed from opened Master Overhaul Kits. These won't be listed, but if we have a part in an incomplete kit, we will sell it, otherwise we will not break a kit. Prices and availability are subject to change without notice. The master overhaul kit is on our web site, as are some other parts, but not our online store. So to buy these now, you will have to contact us. This will change, but as of right now, we have not had time to get these loaded into the store. Items in bold are the most common items people will need for routine service or common issues. I know this isn't the most forum friendly as it is pasted from a quick books report. Basically if you need an SST part, and it is available from somewhere, we have it or can get it. We attempt to keep all of the parts on this list in stock at all times.
NOTICE: NONE OF THESE PARTS ARE INTENDED AS PERFORMANCE UPGRADES!! THEY ARE INTENDED AS REPAIR OR SERVICE ITEMS ONLY. WE MAKE NO CLAIMS REGARDING ANY OF THESE PARTS ABILITY TO EXCEED OEM POWER LEVELS!
Effective 8-16-2013
Service/Repair parts list:
K27 DCT470 2.2SP Steel End Plate (2.2mm) 0.00
K27 DCT470 ASC-1 M/C Seal, Axle (Converter) (also requires K27 DCT4... 12.93
K27 DCT470 ASC-2 Seal, Axle,Converter Side, inner, Getrag DCT470 (A... 19.80
K27 DCT470 ASC-K Output Shaft Seal (axle seal), Converter (T-case) sid... 31.23
K27 DCT470 ASD M/C seal, axle, DCT 470 (Differential) 13.20
K27 DCT470 CMK-E Economy Friction and Steel Module kit for Getrag D... 741.00
K27 DCT470 EF DCT470 external filter (SST) FILTER ONLY (Bowl g... 36.57
K27 DCT470 EFG O-ring, filter bowl, DCT 470 (SST) 5.20
K27 DCT470 EFHCS Gasket, external filter housing, DCT 470 9.75
K27 DCT470 EFK Kozmic Motorsports DCT470 (SST) External Filter K... 36.57
K27 DCT470 FME Economy Friction Module, Getrag DCT470 (clutches... 370.00
K27 DCT470 HUB ORING O-ring, hub shaft, DCT470 ( SST) 5.52
K27 DCT470 MF DCT470 internal filter (SST) Main 36.57
K27 DCT470 MOHK-STD Master Kit, DCT470, w/piston and front cover. Includ... 1,659.65
K27 DCT470 MPS-1 Molded Piston (Clutch Seals), Getrag DCT470 (SST... 48.65
K27 DCT470 MPS-2 Molded Piston (Clutch Seal), Getrag DCT470 (SST) ... 73.10
K27 DCT470 MSS M/C seal, Manual Shaft (Shift lever) DCT470 13.50
K27 DCT470 MVBGL Gasket, metal, V/B to case (large), DCT470 25.50
K27 DCT470 MVBGS Gasket, metal, v/b to case, (small) DCT 470 22.92
K27 DCT470 NVBCB Checkball, Nylon, DCT470 1.65
K27 DCT470 OHK Overhaul Kit, SPS6, DCT470, W6DGA 2009-12 min... 742.00
K27 DCT470 PG Pan Gasket, DCT470 (SST) 23.10
K27 DCT470 PVBG0 Gasket, V/B to case upper, DCT470 (valve body inte... 15.90
K27 DCT470 PVBG1 Gasket, V/B to case Lower DCT470 (Valve body int... 15.90
K27 DCT470 SFPL Molded Piston, shift fork, large DCT470 20.40
K27 DCT470 SFPS Molded Piston, Shift fork, (Small), Getrag DCT470 19.50
K27 DCT470 SM Steel Module, DCT470, standard. (Will NOT work wi... 371.00
K27 DCT470 SSRK Kit, Stator Ring Seal DCT 470 280.00
K27 DCT470 VBSCB Checkball, steel, DCT470 2.78
K27 DCT470CCSPK Kozmic Motorsports DCT470 Clutch Compartment S... 499.99
K27 DCT470ERP Kozmic Motorsports Ecconomy Race Pack Clutch Ki... 1,172.05
K27 DCT470MPK Molded Piston Kit for Getrag DCT470 (SST). (Does ... 275.21
K27 DCT470SG Gasket, Stator, DCT470 5.20
Performance Upgrade Parts List:
K27 DCT470 ERP FSK Kozmic Motorsports DCT470 (SST) Ecconomy Race Pack Full Service Kit 1,672.04
Effective 8-16-2013
Last edited by KozmicMotorSpts; Aug 16, 2013 at 04:53 AM. Reason: added items to list, updated pricing and part numbers
Kozmic Motorsports announces the Economy Race Pack Full Service Kit for the Getrag DCT470 (SST) Transmission. Price $1672.04 shipped to anywhere in the USA.
We have added parts to our SST component line up.
Most significantly we have introduced an Economy Race Pack Full Service Kit for the SST.
Link: http://kozmicmotorsports.com/product...l-service-kit/
The Economy Race Pack Full Service Kit is a 10 disc clutch kit that includes ALL of the parts recommended to refresh the clutch compartment. This includes
10 Friction Discs
Steel Plates
Premium Clutch Pistons (Seals)
Hub o-ring, Stator Ring Seals
External Filter
External Filter Bowl O-Ring
Transmission Pan Seal.
This is the most complete SST clutch kit available at a price that is hundreds less than similar kits sold by other companies.
This clutch kit has been extensively tested by us in house. We give this clutch kit a no bs 400 lb/ft torque in service rating. The in service rating is the maximum torque at which a reasonable clutch life can be expected. We have tested this kit to higher torque on our Mustang Dyno*. Racing applications can exceed the service rating, however clutch life will be reduced.
* A stock Evo X MR makes 225 hp/235tq on this dyno. Determine if this clutch kit is right for your vehicle accordingly.
Coming soon: The "Magic Pack". The ONLY clutch kit PROVEN to shift in full auto mode at 9000rpm and 650+ hp.
10 Friction Discs
Steel Plates
External Filter
how long does the service take to install and how much?
My goal is to hit 600+ wheel hp
I am cresting 400 so it is a long road, i plan to do forged internals and a percision 6266 turbo and that should get me there. But the MR transmission can't handle it... I am looking for best bang for my buck, i am torn between SSP and Jacks. I just heard about you guys so i am intrested in what you can offer me. Thanks in adavance for your time. Your kit looks promising and i love the price.
My current mod list is
ARK Turbo Timer
ETS 4" FMIC
ETS UICP
ETS Intake
GSC S2 Cams
GSC Retainers and Springs
Synapse BOV
CNT Racing Turbo back Exhaust
Grimmspeed EBCS
FIC 1100cc Injectors
DW 265lph Fuel pump
30psi Stock Turbo
COBB AP E-85
COBB AP 92 Octane
ARK Turbo Timer
ETS 4" FMIC
ETS UICP
ETS Intake
GSC S2 Cams
Synapse BOV
Grimmspeed EBCS
DW 265lph Fuel pump
30psi Stock Turbo
COBB AP E-85
COBB AP 92 Octane
tequila357
Feb 18, 2016 11:42 AM
BehindSpace999
Mitsubishi TC-SST Discussion
Sep 29, 2014 03:21 PM
KozmicMotorSpts
EvoX 'For Sale' Engine Internals and Drivetrain
Dec 6, 2013 08:27 PM
