MAPerformance Custom Downpipe for FP Stainless Housings!
MAPerformance Custom Downpipe for FP Stainless Housings Now Available!
Find them here!!!
Forced Performance recently released a stainless steel turbine housing for their Evo 8 & 9 turbochargers that does not allow for the use of stock frame exhaust components; Thus the need for customized components for which MAP has the solution.
-Full 3" stainless steel tubing
-Smooth tight radius bend from the turbo outlet allows for retention of air conditioning
-Full 3" flex section with interlock liner designed for longevity in high temperature forced induction applications
-Your choice of external or recirculated wastegate dump
-Finish ported for maximum exhaust flow
-Factory 2 bolt connection to catalytic converter or test pipe
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||: MDunn@MAPerformance.com|||||: 651-348-8811 x 107|||||: MDunn@MAPerformance.com|||||
Any chance you could make a 3 bolt flange to bolt up to the AMS test pipe? I could always cut the flange off my AMS DP and weld it to this one but id rather sell the AMS to get funds for this one
