Evo X Intercooler by MAPerformance | Available Today!!!
Introducing the Mitsubishi Evo X Intercooler Upgrade brought you to by MAPerformance!
Our MAPerformance 3.5" Evo 10 Intercooler upgrade is designed as a direct bolt in for any Evolution X or Ralliart (when using an Evo X style UICP)! Suitable for almost any build this beast can support up to 700hp and look great doing it.
![](http://cdn.shopify.com/s/files/1/0890/6136/products/DSC_3587.jpeg?v=1447276774)
Lowering your Evo X air intake temps will equal more power throughout your power band. Our MAPerformance Evo X intercooler core upgrade is one of the most desirable options due to its extremely efficient cooling (1050cfm at just 1.5psi pressure drop) and the added benefit of being an easy bolt-in upgrade. Investing in this high quality Evo X Intercooler will ensure you're extracting maximum performance from almost any Evo X setup while enjoying the ease of a straightforward installation. Manufactured right here in the USA ensures you're going to love this products performance for many years to come.
![](http://cdn.shopify.com/s/files/1/0890/6136/products/DSC_3592.JPG?v=1447276777)
MAPerformance Evo X Intercooler Features:
- Evo 10 Intercooler Core dimensions: 3.5" x 11" x 20"
- Core Design: Bar & plate construction for maximum efficiency (1050cfm at just 1.5psi pressure drop)
- Easy Bolt In Design: retain you factory Evo X crash beam, compatible with both OEM or aftermarket 'Evo X style' intercooler piping
- Fool Proof: CNC machined inlet and outlet to ensure couplers and piping remain in place
- Performance: Rated to 700hp
- Quality: Pressure checked to 35+ PSI
- Application Notes: Will fit all 2008+ Evo 10 & works on 2009+ Mitsubishi Ralliart when using Evo X style upper intercooler pipe.
