Random Technologies High Flow Cat
#33
Hey man, how did the cat work for you? What numbers did you put down with the cat and i/c piping? I wish I coulda stuck around to see yours...
Bobby
Bobby
#34
I've had mine installed for about three months now. No catalyst efficiency CELs until just a few days ago, and now I'm finding that I'm getting an catalyst efficiency CEL after repeated high rpm runs. I cleard the first CEL, and a few days later when I got on the throttle again, I got another CEL. Seems that the Random Tech cat can't match the stock unit's efficiency. If you have seen the stock cat, that may surprise you because the stock cat has two catalyst bricks with the rear O2 sensor sitting in between. The first brick is quite short, and I wouldn't think that it offers much catalyst capacity.
#37
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
#41
I have the cheater and the only cel I throw is the p0300, and as far as exhaust fumes it seems about the same as stock to me (although I can't say compared to test pipe, never had one).
#42
![Stick Out Tongue](https://www.evolutionm.net/forums/images/smilies/tongue.gif)
you could almost put your nose in my tailpipe stock and not smell anything, so thats good!
#45
if the random tech cat is carb approved then what is the CARB EO number? i wasnt able to find it in the carb website http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
