Stock MAF Sensor Gasket Help
I have the buschur air filter kit which comes with a maf adapter and gasket. seems that no matter how tight i bolt the gasket between the maf and adapter the gasket will not seal.
i ran a piece of wire through where the gasket is not sealing.
gasket is flat and maf is an unflat surface so im not sure how its supposed to seal unless i use the stock gaket also. So my question is... Should I be using both the stock maf gasket and the maf adaptor gasket? I tried an it seams better this way. Any suggestions are appreciated.
4cefed
11
Nov 24, 2008 03:19 PM
