HIR [sic] High-Beam Lights
http://hirheadlights.com/
Has anyone tried these? They google well and people seem to have nice things to say about them on various other boards.
Do you know if the bulge in the bulb will fit through our high-beam aperture?
I'm not looking for an HID conversion - these are simply regular halogens that put out mega-lumens.
Thanks!
Thanks!
I have the HIR's for my highbeams and they are incredible. Not much more to say then they clearly overpower the OEM bulbs. There are no clearance issues, as they were designed to fit through the hole in the housing.
HIR technology is patented and proven. While a standard halogen bulb emits a broad spectrum of light (including infrared light), HIR bulbs use a special reflective coating to selectively reflect and transmit the light it creates. The special coating takes the infrared light/energy and reflects it back onto the filament. This design reduces the amount of power needed to keep the filament hot thereby, increasing light output, life span and efficiency.
The upper bulb, which is similar in appearance to a Xenon capsule, is actually the first generation HIR bulb developed and patented by G.E. One of the problems with GE's design is that the bulb is long and fragile, and would often crack and cause premature bulb failure. Lamp selection is also limited due to the bulb's long length. The G.E. patent was eventually licensed to Toshiba, who redesigned and improved the HIR bulb design. The second generation Toshiba bulb is not only super reliable, but also lasts longer and emits more light.
Awesome - thanks. Any issues with longevity of the bulbs?
Ahnospell44
04-06 Lancer Ralliart How To Requests / Questions / Tips
13
Sep 5, 2007 01:01 PM
