X-WiFi Wideband UEGO and EGT Wireless Gauge Controller
AEM came out with this new product and I would like to inform you guys about what it actually does and what it is capable of. I guess everything is compatible with iPhones now a days ![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
![](http://www.evasivemotorsports.com/Merchant2/graphics/00000001/aemxwifi2.jpg)
![](http://www.evasivemotorsports.com/Merchant2/graphics/00000001/aemxwifi.jpg)
WHAT IT DOES
The AEM X-WiFi is the complete exhaust gas monitoring and tuning tool, combining the legendary AEM wideband UEGO and up to two EGT sensors in one compact, easy to install module. On top of that, the X-WiFi displays accurate, real-time, AFR and EGT data in a user-friendly layout via the standard web browser on virtually any WiFi enabled electronics device such as the iphone, droid, and storm2. The AEM X-WiFi also offers a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC. Data stream output is included for PC viewing of AFR and EGTs via USB cable.
WHY YOU WANT ONE
Easy to conceal, yet simple to connect to wirelessly, the AEM X-WiFi system features a Bosch sensor with an accuracy of .1 AFR, making it among the fastest and most accurate widebands available. When used with the two K-Type EGT sensors, the X-WiFi gives fast and accurate reference to real-time exhaust gas conditions, for easy power tuning. With clean and easy installation and simple data viewing, the X-WiFi lets you monitor your Air/Fuel Ratio and EGT from a wide range of wireless devices and can be configured for either direct (adhoc) or network (infrastructure) WiFi communication. Bottom line, the X-WiFi is a must have for tuners and enthusiasts alike.
- Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
- No laptop or dedicated display required for monitoring
- Bosch sensor included
- Accurate to 0.1 AFR
- Optional EGT sensors sold separately (see drop down menu to add 1 or 2 sensors)
- 0-5v analog outputs included (ARF, EGT1, EGT2) for use with data loggers and virtually any engine management system
- Serial data stream included for output of AFR and EGTs via USB cable
- Detects AFR sensor problems and outputs error values which can be used to deactivate feedback
- Reads EGTs from 0-1800F
- Reads Gasoline AFR values from 8.5 to 18:1 AFR
- Reads E85 AFR from values 5.7 to 12:1 AFR
- Reads Ethanol AFR values from 5.2 to 11:1 AFR
- Reads Methanol AFR values from 3.7 to 7.8:1
- Reads Lambda values from 0.58 to 1.22 AFR
If you have any other questions about this product feel free to shoot me a PM. Since it is fairly new it might take a while if I can't answer it. It'll have to email AEM to get an answer of course![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Dennis @ Evasive
WHAT IT DOES
WHY YOU WANT ONE
Dennis @ Evasive
Saw that info from other forum (by adam@ www.z1auto.com) I saw youtube vid about how wifi connect and how it works, if anyone interestin to watch, check out youtube.
Edit: http://www.youtube.com/watch?v=-RlqOQ1TdGQ
maperformance
Sep 7, 2010 01:39 PM
Z1 Performance
EvoX 'For Sale' Electronics / Lighting / Audio
10
May 22, 2010 11:59 AM
maperformance
Evo 'For Sale' Electronics / Lighting / Audio
332
Jun 2, 2009 09:03 AM
EmeryatSTM
11
Nov 28, 2008 08:42 AM
