CBRD does it again
CBRD does it again
Went to CBRD today to get my car tuned. As usual had a great experience there. i want to say thanks to chad for coming in on a saturday to get my car done. i always look forward to going to this shop. this is the only shop my evo will ever goto and the only one that will tune my car. thanks again man
I had chad boost leak test my car before it went on the dyno. everything was good. we came across a problem with my blow off valve not wanting to close at idle, but he tried his best to fix it. really theres nothing that can be done except order a new spring for it. so no big deal. i appreciate his effort. he also fixed an exhaust leak i had
then car went on the dyno and all i can say is wow. the drives amazing and its very smooth just cruising, but then just turns into a beast. the car made 463whp and 376wtq on his dyno at only 25psi of boost on pump gas. we didnt want to push the car since im on stock headbolts still. the car is stock block and stock head still also. its a pretty safe tune. definately a lot more left in this car. i was told that i now hold the stock block WHP record for CBRD's dyno too
heres a pic, i have video. ill put that up later
check the license plate
i dont have a way of putting up my dynochart, so if chad wants to throw it up on here i dont mind.
ets hta3586 kit
1200cc injectors
gsc s1 cams
ets 3.5 intercooler and piping
Milspec 65mm TB
spooling up COP ignition
3" exhaust
stock block
stock head and valvetrain minus cams
stock head bolts
stock intake mani
like i said there is A LOT of power still left in it, but this car is my daily driver so ill take safe tune over agressive tune for a few more ponies
1200cc injectors
gsc s1 cams
Milspec 65mm TB
3" exhaust
stock block
stock head bolts
stock intake mani
