Blaq Ops fuel pump kit users - READ THIS
Short and sweet. Had a tuning session on E85 yesterday @ Church Auto. During my first few passes, my tuner told me my ID 1000's were maxed out at like 365 HP. We shut it down to locate the problem. I told him that I had been having intermittent starting issues recently. IMMEDIATELY he said "You are running a Blaq Ops kit right?" I said yes, and he said "I already know what it is". He told me that the fuel line from the pump was split. We pulled the pump out and sure enough...
The line from here to there:
![](http://i494.photobucket.com/albums/rr309/planbms/IMAG0912.jpg)
Looked like this:
![](http://i494.photobucket.com/albums/rr309/planbms/IMAG0911.jpg)
![](http://i494.photobucket.com/albums/rr309/planbms/IMAG0910.jpg)
I asked how he knew what it was so quickly, and he said that it happened to him as well about a month ago. He said mine was huge though (and yes, that's what she said). This isn't meant to bash Blaq Ops in any way. I love the products and it has served me well. This is simply a warning to any Evo owner with this kit that is using the supplied line. We know what happens to Evo's when they don't get enough fuel![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
If you own this kit and have any weird fuel issues, CHECK THE PUMP! It takes 10 min to pull it out.
Looked like this:
This happened to me as well. Mine was split so badly that the car would stumble as soon as it started going into load. When Cobb diagnosed the issue I was running only a few lbs of fuel pressure. They replaced the hose and I hadn't a problem since.
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
I would hate to see a fellow owner go down because of this. It's like the relay problem...stupid problem w/ a potentially catastrophic result.
This might be what you need: http://www.gates.com/brochure.cfm?br...ocation_id=541
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
We've had similar issues.
Had a Genesis coupe come in the other day with the same problem.
The Gates Submersible is the only stuff we use now.
Best of luck.
Cory
Best of luck.
Cory
