Mellon Tune, Stock Block PTE 6266 Rocks!
I visitted Mellon Racing this week to get a PTE 6266 installed and tuned. The drive was 960 miles and well worth it!! Chris has always provided the best service and superrior tuning
results in the past, and I was thrilled with the power results that this trip provided. I was looking to be in the for 500 WHP range, he exceeded this by 50 HP. The transient response was phenomenal for a bigger turbo. I would highly recommend Mellon for anything your evo needs. I will get Chris to post the results in the Dyno and Tuning section. Mellon Rocks!!
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
1 Post
thanks for making the trip Eric, I should have had a long distance award winner trophy for ya, that was quite a haul and I'm still flattered you've been so loyal to us.
here were the results:
![](http://img.photobucket.com/albums/v47/Mellonpopr/EVO/Tune%20Comparisons/564430440lbs30psi.jpg)
FP Green at 25psi vs PTE 6266 .63 @ 30psi, both on 93 octane
![](http://img.photobucket.com/albums/v47/Mellonpopr/EVO/Tune%20Comparisons/fpgreenvs6266.jpg)
![](http://img.photobucket.com/albums/v47/Mellonpopr/EVO/Tune%20Comparisons/20121123_204502.jpg)
![](http://img.photobucket.com/albums/v47/Mellonpopr/EVO/Tune%20Comparisons/20121123_204454.jpg)
Eric
forum name EVOEMS
Year 2005
Make EVO9
Tranny 6-speed
Tire Size 235/45/17
cargo weight 440
Spec USDM
Fuel Pump twin buschur
Injectors PTE 1000
WB02 aem uego
Octane 93
Boost 30
Exhaust ETS T3 header/02/dump/downpipe, test pipe, magnaflow muffler
Intake Perrin foam filter, customer intake pipe, APS twin vent bov, Garrett 3.5" core FMIC, Buschur ported intake and throttle body, ETS licp, custom UICP
Cam GSC S1, supertech dual springs
Turbo PTE 6266 .63 CEA turbine
Result VD 567/423
Other customer ported/polished head, stock valves
Package road 400
Location St. Louis MO
Eric
forum name EVOEMS
Year 2005
Make EVO9
Tranny 6-speed
Tire Size 235/45/17
cargo weight 440
Spec USDM
Injectors PTE 1000
WB02 aem uego
Octane 93
Boost 30
Result VD 567/423
Package road 400
1 Post
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
1 Post
He didn't want to buy new injectors so he went twin pumps.
1 Post
Eric likes his little S1's because they idle so well for daily driving but I can't help but wonder what it would do with some S2 or even S3's. 600awhp on the stock short block and 93 octane would be pretty impressive.
1 Post
I don't remember for certain and don't want to guess. I'll let eric chime in since he's daily driving it and can verify. The goal here was to get FP black type of spool but T3 kind of power on pump gas.
I am still getting used to all of this new power, I am bouncing off of the rev limiter in 1st and second gears because it cooks through the powerband so fast. As far as spool, I will get back to you, the speed has kept my eyes on the road so I will check and give you an rpm range. I can't say enough about Chris at Mellonracing. When we first started tuning, the torque was way above where we ended up. He had to dial it down to keep the stock rods alive. The kit is from ETS, wonderful quality with a lot of power potential. I would highly recommend Mellon for anything EVO related, very knowledgable and explains everything as he goes through the tuning process. I am going to go to a built 2.3 in the near future, some type of set up like the AMS RR version so I can keep it together above 8500 rpm. Will update with spool soon!
so is it a fun, driveable car on the street? What kind of driving do you do primarily?
I'm a highway runner, I only drive my car around on sunny days and I'm always on the prowl for some friendly competition. I honestly dont like the really small stock turbo because I'm always in boost and there isn't really a big "hit" of power if you know what I mean
This is my daily driver, I am planning on doing some road racing and 1/4 mile drags this spring so I was looking for a nice balanced set up. This is a very streetable combination, the power is just a quick downshift away, full spool is at 4500-4600 rpm, by 5k it is lights out!!! Hits like a brick and pulls HARD to redline. I was concerned that it would not be as streetable as the green, but I am really enjoying the new power, it just takes a little different style of driving. With the 2.3 I should see a 500 to 600rpm reduction in spool. I will post track times when spring rolls around and the track opens. The tune makes the car very user friendly in traffic. I would highly recomend this turbo to anyone looking to wail on the local viper-vette crowd.
Mellon Racing
394
Oct 19, 2014 05:24 PM
