FS: Evolution 8 Engine Parts (Head, Valve Cover, Bolts, Pulleys, Oil pan, ETC)
Payment Policy
I ACCEPT PAYPAL, PAYMENTS VIA CREDIT, TAKE MONEY ORDER, OR ACCEPT PAYMENTS GOOGLE CHECKOUT
Invoices will be sent to every buyer after a purchase
Items will be shipped within 2 business days GUARANTEED... FREIGHT SHIPMENTS MAY NEED UP TO 4-5 BUSINESS DAYS TO PROCESS.
International Shipping is available
No P.O. Box Delivery
Paypal Confirmed Addresses Only
Items Will be Shipped by UPS
FEDEXTracking Number will be provided
Returns Policy
If a item received is not as described or damage i will take full responsibily for the item, please message me asap and we can get the situation handled.
Customer will be charged 15% restocking fees on any items returned with no damages.
Hey guys, i have tons of parts around the who that i need to move.
WE literally have every OEM engine part Used.
Here is Parts List all Evolution 8 motor that had 24k miles.
We do have some 9 parts but please ask.
Hard Parts
Cylinder Head (GOOD) SOLD
Valve Cover (Very Clean) SOLD
Spark Plug Wires w/ Coil Packs $85
Intake Manifold $85
Throttle Body $85
OEM turbo Kit 9.8 Hotside $300
Evolution 8 OEM Crank $395
Accessories
Alternator $100
Power Steering Pump $100
A/C Compressor $100
EVO 8 Clutch OEM $125
Power steering Pump Bracket $40
A/C Compressor Bracket $40
Oil cooler With Lines $125
Dip Stick Tube/ Dip stick $28
Oil Pump (GOOD) $100
Cam Angle Sensor Housing $28
Starter Plate $10
Oil Filter Housing $100
Sensors
Front o2 $85
Map Sensor $45
IACV $100
TPS $85
Emission Sensor (Intake Manifold) $30 EACH
Cam Angle Sensor $40
Knock Sensor $50
Oil Pressure Sending Unit $10
Crankshaft Position Sensor $60
MAF $110
Timing Components
Accessory Belt Idler Pulley $30
Harmonic Balancer (Crank Pulley)$ 65
Lower Timing Cover $45
Upper Timing Cover $20
Cam Gears $20 EACH
Water Pump Pulley $28
Crankshaft Timing Sprocket $35
Crankshaft Timing Sprocket Bolt w/ Washer $10
Crankshaft Sprocket $ 35
Trigger Plate $10
Balance Shafts $ 75
Balance Shaft Sprockets $10
Timing Belt $30
Balance Shaft Belt $15
Timing Tensioner Balancer $25
Timing Belt Tensioner Arm $20
Timing Belt Idler Pulley $20
Cylinder Head Timing Belt Covers $20
Internals
PISTONS w/ Rods $150
Windage Tray $11
Oil Pickup $14
Rockers $15 Each
Lifters $10 Each
Cams $100
COOLING
Water pump $75
Water Pipe $60
Thermostat housing $75
Upper Coolant Hose $12
Lower Coolant Hose $12
Thermostat $5
Motor Mounts
Passenger Motor Mount $45
Trans Rear Motor Mount $25
Driver Trans Mount $85
Front Mount $45
Front Mount Bracket $35
Trans Rear Mount Bracket $18
If theres a Oem Part you can't find listed Feel Free to ask.
ALL PRICES ARE PLUS SHIPPING
Reference Picture
