Evo ECU reflash limit
Look to the right of your steering wheel under the dash. There's a port, like a plug that is used for a flash unit and to read signals from the ecu. There is a flashable chip in the ECU.
You can use a flash unit, like the one made by Techtom, to change perameters in boost limit, rev limit, top speed.
I think it works just like a CF card. It's flash memory, so yeah, I'd bet you could flash 1000 times (and I'll bet the God of Power has come close to that number), but why?
why?
Am I wrong or is the interface for changing ECU mapping parameters propietary to mitsubishi?
d
