spark plugs
yea dont get the Iw01-24 its a purely racing plug. The gap is like .20 (not .24 like advertised) and you will get misfires under partial throttle (trust me I've tried them.) High RPM action feels very smooth though...
I've tried all kinds of plugs and different gaps and found the HKS S40G works best for my setup. The gap I set them to is .026. I've also tried copper ranging from .24 on up to .28 and it just doesnt feel the same as an Iridium plug. Part or full throttle suffers a little no matter how I gap them.
They shouldnt be fouling either, sounds like you have fueling issues. I've gone through more than a few sets now with no issues at all. I could have left them in longer, but hey it's fun to change them ever 10 thousand or so.
Originally Posted by hutch959
BR8ES...
Arent those XR50R plugs???
Go-Kart and Motocross plugs in an Evo. LOL They might work if they recommend them.
Originally Posted by EVOTEXAS
Don't waste your money on iridiums. I had some and they fouled in 1500 miles. Too much money for such a short crap life. Just spend 8 dollars instead of 60.
Originally Posted by 93civEJ1
who cares??? You do know that spark plugs are universal correct? They arent vehicle limited. This is what im running as well as many others. The br8es.
I ran a set of these (don't ask how) and the stock plugs are better for my street use. The claim is that they will not foul given their design, but they are too cold for my stop and go driving and the anti-foul design wasn't good enough.
My take is that these should be reserved for a track day.
Originally Posted by Event-Horizon
Denso IW01-24
What gap, then?
I got the BR8ES and gapped them to .28 per the how-to here on evom. Seems like folks lean towards .26 or other.
Should I gap them closer to .26?
What would the symptoms be of having too wide a gap?
FWIW, the car had a certain idle roughness that was significantly improved with the new plugs.
thanks
thanks
I've been running these plugs since last October when I was last tuned. I've never had any problems with them. The car runs smooth and has never skipped a beat. I've pulled them several times, and they have the tannish-white color of a normal plug. They have never been black from running too cold or fouling out. I think these plugs will last a long time too. When you have these plugs it is probably best to be tuned for them.
Originally Posted by EricR
Use BR8ES plugs gapped at about 0.027. They're cheap and they work well. Change them every oil change. They're also recommended by Vishnu.
Thanks
leoni101
Jul 23, 2016 08:23 PM
FS[Northeast]: NNJ, Laser Iridium Spark Plug BNIB $32 shipped
dtfrost5
Feb 18, 2016 04:14 PM
sophic
Feb 19, 2006 08:04 AM
