Gas Prices too high - time for FFV mods?
Old Sep 13, 2005, 11:17 AM
  #106
zyounker's Avatar
Originally Posted by RFH
not true as E85 is 33 % 02 by weight, so the extra air is in the fuel, also as E85 evaporates it cools, meaning denser air entering the combustion chamber.
the fuel with the most o2 and heat of evaporation will make the most power.
to map for E85 you start by adding 27% to the entire map. then with a wide band then tune fuel by A/F (different than gas with stoich at 9.96)
then once A/f is correct for max hp, egt limit, etc
then tune spark for MBT , presto E85 map.
Who has a wideband that reads below 10:1?
forced induction running e85 *may* produce equal/more power.
But in NA applications it will produce less power. When you inject 27% more fuel That takes up room that would have been air.its not gonna produce 27% more air as well from evaporation.
Fuel without air is useless.
Now when you can compress more air into the intake track, that is a different storry.. Do you or anyone have any information/dyno sheets from a boosted car?
zyounker is offline
Old Sep 13, 2005, 11:24 AM
  #107
donour's Avatar
The LC-1 does.
d
donour is offline
Old Sep 13, 2005, 11:45 AM
  #108
djh
djh's Avatar
Making a WB that reads below 10:1 is easy. Making it accurate is impossible with a Bosch LSU.
The lower the AFR of the fuel the higher the effective volumetric efficiency of the engine. The extreme example: nitromethane. Heat of combustion and other factors come into play, too, but in the end you can make at least as much power on ethanol as gasoline. It's been done.
Dave
djh is offline
Old Sep 13, 2005, 01:13 PM
  #109
donour's Avatar
There's two issues there and we're addressing different ones. 1st is: is the controller capable of dealing with voltage ranges indicitive of <10:1. 2nd, can the sensor really provide accurate data down there. You're probably right.
d
donour is offline
Old Sep 13, 2005, 03:10 PM
  #110
RFH
RFH's Avatar
yes the process is the same for E95
also the WBo2 will read AF correctly, however you need to realize that stoich for E85 is 9.96 so the voltage the sensor out puts at 14.7 on gas will = 9.96 on E85, you need to adjust the scale of the out put
as far as NA making more power. Infact at school I converted an engine to run on E85 and dynoed 2.5% more hp from the fuel change alone(turbo will be much higher with increased boost and timing).
It is possible becasue E85 is actually 33% oxygen by weight, thus providing enough air for combustion.
This is because of the increased latent heat of evaporation, denser charge and higher resultant IMEP. If you still question me look up a SAE paper on this done by FORD, they claim 5% NA from the switch.
unfortuatly I cannot provide any graphs.
RFH is offline
Old Sep 13, 2005, 05:31 PM
  #111
MalibuJack's Avatar
Many wideband setups (the TurboXS tuner) has an ethanol setting that rescales it... or you can work from lambda value instead..
MalibuJack is offline
Old Sep 22, 2005, 08:45 PM
  #112
RFH
RFH's Avatar
correct
bump
RFH is offline
ChipperEvo
Nov 18, 2016 01:06 PM
Acree
Jun 23, 2011 02:08 PM
TTP Engineering
E85 / Ethanol
Aug 2, 2009 06:14 PM
mrfred
E85 / Ethanol
Jun 29, 2008 08:57 AM
Noize
May 9, 2008 05:42 AM
Quick Reply: Gas Prices too high - time for FFV mods?
