gm maf?
gm maf?
has anyone tried using a maf translator and a gm mass air meter on an evo? what kind of things may i encounter by trying to use one? i have no problem with experimenting and attempting to calibrate one. any advice from someone who has tried it? or uses this type of set up on a dsm?
I'm using a ford Cobra MAF, but its functionally similar..
It works really well, at least my setup does.. It takes some time to calibrate and set up. And Shiv and I pondered how difficult it would be to integrate a GM MAF sensor (or any analog maf sensor for that matter) in place of the Karmann sensor and map the frequency to the voltage..
The advantages of a blowthrough MAF is much larger airflow capacity than the stock MAF.. not so much in CFM, but in signal, what I mean is, when you get very high air volume or speed going through the sensor, or compressor surge, or recirculation from the DV, you cause anomolous readings, in some cases depending on conditions you may never get the same reading twice, which makes tuning frustrating at least. With a blowthrough MAF, you don't have those issues.
The blowthrough maf does have some disadvantages though, lag in airflow can cause some amount of tip-in lean condition as the MAF signal lags behind the throttle input, so you need some way of compensating tip-in. Also, its a little time consuming to match the signal to the OE Karmann signal. I think I adjusted mine for several months before I was close. Sometimes idle can be affected as airflow lags behind, but this only applies to sensors that don't have a lower-limit that can be set (mine doesnt do that because it will never go below 32hz no matter how the engine idles)
If you have the time and patience, I think its a worthwhile effort, and has benefits over both the stock MAF and the compromises you make with speed density..
Anyone who has ridden in my car always comments about the stable and smooth idle, the linear pull, and the stable readings, so it says alot for the sensor since the car is way more drivable than it was before I did the sensor.. and I'm talking conditions where its really hot and muggy, where your idle might typically be troublesome due to engine load of the alternator powering the fans..
The not so important side effect of a blowthrough MAF is if your DV/BOV is located before the MAF sensor, you will never meter air thats vented, and therefore don't have to recirculate. However, the cost involved in doing this can never justify doing it for this reason...
To do his right, expect to modify your upper intercooler pipe, and spend $500 or more on the components needed. What I'm hoping is that the Xede (and soon the UTEC) will have the ability to use aftermarket MAF sensors built in, and some instructions on how to do it.. Hopefully I can offer what I've learned to benefit everyone..
i had this setup on my vr4. it worked well because the factory first gen maf was such a pile. when it comes to the evo the maf is light years ahead. after personally dynoing an evo with the stock maf and an afc to 516whp i see no need to upgrade it. the gm performs well but when the stocker will get over 500whp why bother?
Originally Posted by EVIL_EV0
Unless you are running a big **** turbo does it really make sense to move away from the stock maf?
Originally Posted by Drews_WRX
WOW, thats impressive. Whos EVO is this?
http://www.socalevo.net/forums/viewtopic.php?t=11595
track results can be found here:
http://www.socalevo.net/forums/viewtopic.php?t=11650
I used to run the GM MAF and translator on my 1g Talon and had great luck with it but as was already mentioned, that was a huge upgrade over my 1st gen MAF. Its probably not needed on an evo due to the better stock MAF. The blow through setup is nice since you are getting the correct air/fuel mix even if you have a boost leak or have a VTA BOV. You are only metering air that is going into the throttle body.
