New Xede Power Record Tests Limits of Stock MAF
Old Oct 1, 2005, 01:41 PM
559EVO's Avatar
thats some good numbers!You said you got it tunes today and you posted this thread a 630 am then that means you must have been up early.
559EVO is offline
Old Oct 1, 2005, 03:45 PM
erikgj's Avatar
Congrats tom. With enough fuel you really have a monster. How does it drive with this tune?
erikgj is offline
Old Oct 1, 2005, 05:42 PM
Smogrunner's Avatar
I moved this thread here https://www.evolutionm.net/forums/sh...d.php?t=161849 in order to get a broader discussion. There are pics....
Smogrunner is offline
Old Oct 1, 2005, 07:55 PM
Smogrunner's Avatar
MBGSTI,
You are on crack. Your bro's car was a beast, but would not have made more than 530whp/440ftlbs on this dyno. And those numbers would have occured far later in the power curve. I have personal experience with both dyno's, you only have an axe to grind. You are wrong. Bring your forever broke STI south for an *** whoppin'. When you do, you can rest assurred, I'll run it a bit north of 27psi....
Old Oct 1, 2005, 08:46 PM
leif's Avatar
^ yeahhhhh.
smoggie when are you coming up to see all of us???
leif is offline
Old Oct 1, 2005, 09:22 PM
EvoM Administrator
Noize's Avatar
Originally Posted by MBGSTI
So i assume that means Smogs car would be in the low 10's...I hope thats the case
In your dreams. You're such an e-thug and a Vishnu forum troll.
Bring timeslips and results. Not rice math as usual. Does your STi even run?
Noize is offline
Old Oct 1, 2005, 09:26 PM
EvoM Administrator
Noize's Avatar
Originally Posted by Smogrunner
MBGSTI,
Why waste the extra boost on him? You would probably donkey punch his shapile with ease at only 24psi.
Noize is offline
Old Oct 1, 2005, 09:54 PM
shiv@vishnu's Avatar
Hey hey... our red shop car, with the GT35R made 490whp on our DD dyno (30+psi, 125oct, chompin on fingernails, fingers crossed.) Or about 70 DD whp more than IE's which made 500whp on TT's AWD dynojet. So I think it's safe to say that the old XEDE power record still stands... But not for long by the looks of it... eeeks!!!
shiv
shiv@vishnu is offline
Old Oct 2, 2005, 04:54 AM
ez76's Avatar
Yes, but what is the XEDE power record on the Land & Sea dyno?
ez76 is offline
Old Oct 2, 2005, 07:18 AM
gsujeff55's Avatar
7893whp
gsujeff55 is offline
Old Oct 2, 2005, 10:39 AM
20valves20lbs's Avatar
MBGSTI,
20valves20lbs is offline
Old Oct 2, 2005, 12:30 PM
value's Avatar
Smoggie would alky injection make a difference with your numbers ? or with race gas it isn't really needed or worthwhile . Nice $$$'s for sure. Droooling over keyboard.
value is offline
Old Oct 2, 2005, 01:06 PM
Evo_Jay's Avatar
a little off topic but why would you "Removed plastic undertray". Isn't it there for a reason???
Evo_Jay is offline
Old Oct 2, 2005, 01:47 PM
Jaylenospoolboy's Avatar
Originally Posted by 20valves20lbs
You just threw that up 'cause you like the picture
Jaylenospoolboy is offline
Old Oct 2, 2005, 03:36 PM
lambtron's Avatar
it is there to **** you off everytime you need to get to something in that area. It does serve a purpose sorta..i mean it does guide air toward/in the general direction of the brakes....and it catches socket wrenches that slip out of your hands.
lambtron is offline
Quick Reply: New Xede Power Record Tests Limits of Stock MAF
