Vishnu Olins "Gerrard" Spec setup
#167
Originally Posted by meanmud
Finally - My Vishnu-Chrono Ohlins are installed. Now I'm outta money
400bhp/400lb-ft (Vishnu tuned of course) & Ohlins and nowhere to go At least a month away from a track.
#169
It feels incredible Somewhat spirited driving over the weekend.
I need to get to Summit Point ASAP - shouldn't have said anything until then
Paul - can't say enough how incredibly helpful you've been Huge THANKS!
Make sure you run the proper click settings both on the road and when you get to the track (the car and the shocks are quite sensitive to even single click changes). Have fun and let me know how she goes
#170
muddy, come on up to summit june 23rd with rob and i. see if you can get on the waiting list... that fatt is at shanondoah track which will give your suspension a good work out
#171
So the results of this thread up to this point are as follows?
1. There are no Ohlins available due to a supply disruption and there is no expectation as to when they might be coming in.
2. The price is still TBD.
If thats incorrect, please correct.
#172
As far as the supply goes, I wouldn't hold your breath...
But then again I could be wrong.
#175
Originally Posted by Smogrunner
Hey Paul,
Are your Perrin rear end links adjusted to be as short as possible? Comparing them to the stock ones, when the Perrin's are adjusted at full short, they are only about an 1/8" shorter than stock. Shouldn't this preload the stock swaybar just a bit?
I must say - the more I drive this car "spirited", the more amazed I am
Once I get back to the track, I will write up a report and snap pics - Paul, we can't thank you enough for your support
Troy
#176
Troy
But so far, the ride is acceptable on the street. You feel every indentation in the road. All but the worst bumps are easily soaked up and overall I am very pleased with the setup.
This weekend I will have a chance to flog the EVO in my next autocross round, I will keep people posted on what I think..
#177
Hey Paul,
To check all you need to do is loosen one side when the car is on level ground and make sure the bolt can freely move in and out, if there is preload it will be bound by the sway bar tension even with the bolt loose. If preload is present of course all you need to do is spin that side up or down till it freely slide into the hole. Remember the car must be on the level ground at full running weight.
One other slightly off-topic but related thing that's worth bringing up is that the car must be cornerweighted without the swaybars connected.
#178
Originally Posted by chrisw
I recently got my Ohlins rebuilt and revalved to the latest Gerrard spec. I got them back on the car, it feels great, but I have not had a chance to push it because my current street tires are just about to cord...
#179
In other news, We are working on a new set right now. We should know in a few days if the new style ohlins are able to be valved in the same maner. If they are, then we can actually start taking some orders, but one thing at a time.
