Wiring Diagram from Alky to XEDE!!!!!!!
This is a partII of Cajuns post I guess. He is NOT getting answers! I myself would also like to hook up my Alkycontrol (AMS) kit to the XEDE, but is it even ready to do yet? I dont have the SMART system yet, is that required? Does anyone have the wiring diagrams ANYWHERE?
Whatever happened to the Vishnu owners being "tight-nit"? Help if you can, tell me to "get bent" if you want.
Smart isn't required, you only need the meth map that was posted as part of a smart map.
I was incorrect in my prior post on the output Shiv used. This map uses AN2 as the output for the meth controller. AN2 is on black, pin 2
Refer to the attached document.
My understanding is that with the Xede you are using load / RPM to control the meth injection rather than pressure measured by the MAP sensor. The Xede meth map controls the injection rate as a basis of load and RPM. Thus with the Xede you would do away with the MAP sensor and the need for a 5v source / regulator.
I have to admit that you really should have local support and not someone miles away who really doesn't have one of these things in hand. That said I just went through the Xede inputs / output to put together a means of better controlling boost. See the other thread.
