Washington Dyno Day-- Feb 25th
Old Feb 26, 2006, 02:13 PM
  #151
IE Evo's Avatar
Originally Posted by jj_008
He didn't make the event. Maybe next time.
JJ what is the lag difference between this turbo and your 30 r set-up? Looks like it made 40+ whp more so that is good.
IE Evo is offline
Old Feb 26, 2006, 02:26 PM
  #152
jj_008's Avatar
Its tough to say since my wastegate is leaking. Right now, on race gas, its probably close to a GT35R (I hit peak torque at 5300rpm at 34psi and I can't find a good graph of a GT35R on a 2.0l to compare the peak torque values.). On my GT3076, I hit peak torque at 4700rpm at 30psi.
jj_008 is offline
Old Feb 26, 2006, 05:55 PM
  #153
Jim_Patterson's Avatar
Looks like there was some good gains this weekend. I thought WA had 92-94oct??
I was out of town this weekend sorry, I had other plans in Bend.
Jim_Patterson is offline
Old Feb 26, 2006, 09:40 PM
  #154
reactionevo8's Avatar
Originally Posted by shiv@vishnu
Updated results:
boostedwrx-- New EVO IX XFlash+tune Before: 267whp After: 330whp
reactionevo8-- EVO 8 XEDE Before: 267whp After: 314whp(91oct) 341 (100oct)
Elvislives-- EVO 8 XEDE Before: ? After: 335whp (91oct) 365whp (100oct)
jj_008-- EVO VIII XEDE tune RX6 turbo Before 375whp After: 400whp (91oct) 500whp(100oct)
Hexgon-- New EVO VIII Xflash+tune Before: 253whp After: 299whp
(E)VO-- New EVO VIII Xflash+tune Before: 265whp After: 285whp (already had MBC)
Cloud-- EVO IX re-Tune Before: 365whp After: 350whp I detuned him! This new mods made my prior reflash run too lean, with too much boost)
Misc. EVO 8 XFlash Tune Before: ?? After: 315whp
Jaun-- EVO 8 XEDE+tune Before: 248whp After 298whp
jd323-- EVO 8 XFlash+tune Before: 255whp After: 287whp
actually i baselined at 328 then made 332?(i think)on 92 then i made 365 on a mix of 103unleaded and c16...maybe you got confused between me and elvis lives numbers?
reactionevo8 is offline
Old Feb 26, 2006, 09:44 PM
  #155
jj_008's Avatar
Shiv has you and Elvis Lives switched.
jj_008 is offline
Old Feb 26, 2006, 09:46 PM
  #156
jj_008's Avatar
They have 92 octane. I think Shiv is just use to typing 91.
jj_008 is offline
Old Feb 26, 2006, 09:56 PM
  #157
Elvis Lives's Avatar
i didnt have just 267whp!!! ive dynoed in the high 280's to 290's on the exact same dyno!!!
So now i guess Shivs tune got me 20HP????
THAT WOULD BE THE WORST $1100 IVE EVER SPENT!!!!! if thats the case!!!!!!
Whats the deal then Shiv?
Elvis Lives is offline
Old Feb 26, 2006, 10:19 PM
  #158
boostedwrx's Avatar
Which EVO 8's had cams???? I remember hearing reactionevo8 saying his was Stage 1++ I think...
boostedwrx is offline
Old Feb 26, 2006, 10:25 PM
  #159
yea i have the 272's and the 10.5 hotside
  #160
shiv@vishnu's Avatar
Yep.. i think i got you two mixed up... sorry! And yes again, it was on 92oct, not 91oct
shiv
shiv@vishnu is offline
Old Feb 26, 2006, 10:26 PM
  #161
Whoa there.... I'm just reporting what I remembered. You have the dyno graphs from yesterday, don't you?
shiv
Old Feb 26, 2006, 10:28 PM
  #162
boostedwrx's Avatar
post the graphs up! Im curious to see what the tq looks like
Old Feb 27, 2006, 06:51 AM
  #163
i dunno it seems like the power you are making is right considering the minimal mods you have....sure you didnt make huge numbers but now you have something you can tune when you do have cams or a turbo upgrade
Old Feb 28, 2006, 06:26 PM
  #164
miked420's Avatar
shiv, i have called the shop three times and ever time they say that you are not there. today they said that you would call me back when you got there but i never got a call. if you could please call me ASAP it is about the XEDE that you put in my car. by the way my name is michael i was the one that drove you to the airport. you should have my number.
miked420 is offline
Old Feb 28, 2006, 07:05 PM
  #165
Mike,
I've been in and out all day today. It's the first day back from a trip so that is not unusual. I was told that you are throwing a wastegate CEL code which is really easy to diagnose and fix. I asked Sean to tell you to reset the ECU and see if it comes back on again. If it does, I'm going to ask you to look at the blue wire that goes from your XEDE harness to the right-most ECU connector. That needs to be installed in order for the ECU to drive some sort of resistive load (which is the little relay on the harness board). If it doesn't drive anything, it will throw the wastegate CEL. No harm done. You're car will still drive normally. But it will throw the light. Easy to fix.
I installed the XEDE in your car myself and I had a hell of a time getting that wire installed. For some reason, that connector was harder to unlock than usual. The puncture wounds in my hand didn't help either i guess Just make sure that blue wire is in there snuggly (give it a gentle tug to make sure it doesn't come out). That's all to check for now...
Hope that helps and either I or dustin will call you back tomorrow...
Shiv
