Xede wiring help
Xede wiring help
Following the directions as I went through I found everythings place however the xede harness at the ecu "plug in play" harness has 2 wires, looks like speaker wire, one red the other red/black stipe. Nowhere can I find what these go into. I would imagine one is 12 volts but there are 2 actual wires and I don't want to BBQ my ECU. Plus nowhere can I find if its a switched 12v, constant, etc.... Any info would help.
Hmmm...If I recall correctly, these are the map switch wires...not joined together, map bank 0, joined together map bank 1. Xede is powered through the plug and play harness.
Hopefully, someone can chime in to confirm, as I am working off little sleep and an overloaded brain...
EDIT: maybe this will help https://www.evolutionm.net/forums/sh...p+switch+wires
