305whp on mustang dyno: Stage 1 EVO IX Baseline does good
#46
I hit 322whp on that same dyno back in Aug. on 100oct. I had the stock 05 turbo and 272's on it. My pump numbers are in my sig, so these numbers are nothing to sneeze at.
#47
Originally Posted by whitersevo
that is biggest lie.. ever
huh?
#48
how much did this upgrade to stage 1 cost this guy shiv? I know alone stage 1 is 2000, and the V380 flash is like 750, so did you charge him the difference of those two for the upgrade from stage 0 to stage 1 = 1250?
Just wondering if I should get the Stage 1 all at once or get the Stage 0 and then upgrade to Stage 1 later, and if it would be more costly one way or the other.
#49
Originally Posted by atlvalet
Mike Welch from RRE says you do not. Pick your poison.
#50
Technically what the specs say is that if you're staying below the stock redline, you don't need springs/retainers...which is what Mike Welch said in the SoCalEvo thread. It sems by the language Cosworth uses in their specs is that they ASSUME you'll be going higher than stock redline with these cams.
#51
Cosworth is telling you in the first sentence that "proper operation" require the use of springs. That makes sense to me since w/o the springs you might get valve float and the cams will not operate at the optimal level.
#53
Here is what I think..... I dyno'd 300WHP with the 93 octane V390 map (mustange dyno).
I have since driven a 9 with TBE and flash. There is a noticable difference in delivery of power. The 9 does spool faster and hold boost longer. This guys power curve was wider than mine and it was quite noticeable from both the drivers seat and the passenger seat.
I'm not sure if us 8 guys will be able to increase spool and hold power longer without mivec and 9 snail.
The driveability of a 9 also seems to be better than the eight. There are numberous reasons for that.
#54
How much more power do you think this car would have made that day if it used the test pipe?
Also, if he added a better air filter like Works or BMC or Green filter woulden't he get even a bit more whp on the dyno.
I am guessing that he could have got like 325 whp or something around there if he had a test pipe and high flow filter, what do you guys think?
#55
#56
My Dyno At Full Function
Car = Evo Ix Mr
Mods = Garage Hrs CatBack / Perrin Tp / HKS 2.75in Downpipe / Works High Flow Filter / GFB Bov / XFlash /
on 91 octane ( 76 gasoline )
Hello everyone, just got back from Full Function for a baseline dyno and i don't know how to feel right now, but it has made up my mind to buy a turbo kit lol. Now I realatively have the same mods as this other car in this thread exept being my downpipe is 2.75 n his being 3in and i have a Works drop in. Looking over the two charts mines and his, he has 20 more whp as i dyno'ed at 285whp and 278tq and his car dyno'ed at 305whp. But then again I have more AVG. whp by 12whp and more Min. whp both running the same Baseline v400 Map HUH!!!. I hope i choose my mods correctly lol. But at least Sean from Full Fuction said my AFR is just outstanding thank Shiv for that well all in all it was a good day I baselined jus to see were i'm at hopfully i can pick up a turbo kit soon or maybe that 20g-Lt hahaha so many things too little money lol well see
Heres My Dyno
Heres My Dyno
#57
Actually your tune is VERY conservative.....it doesn't even lean out at peak torque. It runs fatter than 11:1 in your main powerband.
Dyno #'s between dynos and cars dont mean a darn thing. If it was all about peak power I wouldn't have my cam gears tuned for a fat midrange. I prefer to have more useable power for daily driving.
