Disconnected battery. Now won't idle.
Originally Posted by Dyno4mance
Check your cam timing...it is possible that you have jumped a tooth or two on your belt... we have seen a vehicle run correctly for a time and then jump teeth if the tensioner is not adjusted correctly... the adjustment is very specific on the Evo tensioner...
The oil pump also needs timing when installing a new cam belt...check that they did this when installing the belt....this procedure requires the exhaust downpipe to be removed to access a plug in the front of the motor...a right PITA
When a CEL is thrown it is always a good idea to read the code and not just reset it as they are not always the codes we assume they are
My 2c
Andrew
Dyno4mance
My 2c
Andrew
Dyno4mance
FYI, if the oil pump was timed wrong ..the motor would vibrate at 3-4 rpms .. As he said it ran find until he disconnected the battery ..
Mark
Turbotrix
Originally Posted by TurbotrixRacing
We are not new to timing motors. .. The tensioner pulley is not losened . I used a rod to push in the tensioner.. Thank you for the schooling on how to time a motor but i think i got it covered ..
Mark
turbotrix racing
Mark
turbotrix racing
If you replaced the belt you would of had to re- tension the new one as no two belts are exactly the same length....I am not trying to "re school" anyone..just trying to help..
you would find that out as soon as you stared the motor not after you drive home...
No....we have had an evo in our shop with exctly this problem it was driven for a period and then jumped teeth....
Oh well I guess we will know the outcome of this mystery soon enough...
I am not wanting to war with anyone
The belt has 14k on it .. Do you think it stretched ????? Mitsubishi gives your a tollerance for the tensioner .. You rotate the motor then let the belt sit ..for a period of time then measure the tensioner. You dont measure the belts .. you measure the amount of rod sticking out of the tensioner .. School is open
Mark
Turbotrix
This was because it was timed wrong ...
Mark
Turbotrix
Originally Posted by sr20det91
Let the flame fest begin.
I think Andrew was just trying to help the guy and you take it to heart like he was questioning your timing skills. I guess Turbotrick is immune to making any mistakes like the rest of us mere mortals.
Mark
Turbotrix
Originally Posted by DEL TURBO
I had a new PE timing belt installed at Turbotrix. The car was running fine. It was about a 2 hour drive home in heavy traffic. At some point, it popped a CEL. When I got home, I removed the belt cover to check it out. I also unhooked the negative battery cable to see if it would clear the CEL. The CEL went away, but the idle is now dropping to 500 or lower when I let off the gas. The car keeps stalling. The car ran great until I disconnected the battery.
Why does the odometer and clock reset when you removed the negative connection, but it doesn't clear the radio settings? I think the radio will only reset when you remove the positive cable.
Whatever his CEL code is ..will be the source of his problem. A motor can be timed completely wrong and not trip a code ...
Mark
Turbotrix
Ok everyone, settle down. I doubt that the belt has jumped a tooth. I would look for possible vacuum line that could have come off. Of course the SES code would of been helpful too.
